I’m old to woodworking but new to hand tools. That is I’ve been woodworking for a long time with power tools but only recentlly began to use hand tools and I find it quite satisfying and also the lack of dust is very good for my old respiratory system. However, I can’t afford to buy all the costly hand planes and chisles new. I do quite a bit of traveling and shopping at flea markets so my question is what should I look for in used planes and tools in general what should I buy and what should I not buy and what about pricing about how much should I pay? What are some good planes and if I find a good plane are parts available for them if they have some missing? What deffects are acacceptable and which are not. I have an old craftsman smoothing plane (about 20 years ) and it seems to work good or maybe I don’t know the difference. I would like to add a jointer and a scrub plane. Any suggestions would be helpful.
Zabo2
I have bought some planes on Ebay but only half were as promised. I have found old planes work quite well. My favorite is a Stanley that i paid $10.00 or so. The irons are another story. I have Clifton, hock, Stanley sweatheart, Stanley and woodcraft. I have found the woodcraft as good as any. The Hock Cyro planes are more expensive and much harder to sharpen. I think the modestly priced hock planes or woodcraft are good enough. Good diamond sharpening stones are probably the best buy. I think the tiger waterstones are very good value. I have an oil stone that is useless. My favorite stones are tiger waterstones but get the large ones. I use my 3 1/2 a lot if you find one buy it.
Zabo2,
What you look for depends on how much time you want to spend tuning it up. Most likely, you'll need (or atleast greatly benefit from) a thicker aftermarket blade. So don't worry too much about the blade condition. Minor rust is a minor issue. Either lapping, electrolysis, a rust eraser, or Evaporust will remove this. The plane sole should be flat, though you can correct slight curvature with a belt sander, etc. If you plan on using the plane for shooting, check that the wings are square to the sole. Totes (rear handles) and knobs are easy to replace, so I wouldn't put too much emphasis on their condition. I would however, make sure that all the parts are there. While spare parts may be available, there are plenty of old planes around that you can be picky enough to choose the complete ones.
I have a feeling that you'll have a hard time finding a scrub plane. #4 planes, on the otherhand, are common. I'd recommend transforming one into a scrub plane by radiusing the blade and removing the chipbreaker.
You will probably find some planes with perforated or corrugated soles. The idea behind these is to reduce the amount of friction between the wood and plane sole. I don't feel that they are effective and can catch on the edge of the workpiece.
Stanley planes or the Sargent equivalents are the most common workhorse planes. There are other good makers, too, but with those, you know more or less what to expect and there are lots of spare parts around. I'd recommend a #4, #5 and #7 or #8 of wither brand -- the Sargents can be numbered differently -- it is the size that counts. Spend some time on the web sites that discuss Stanley and Sargent, to become familiar enough to know that you are buying pre-1950 and ideally -prewar items. # 7 05 #* planes in decent but rusty condition can run you $30 to $50 counting freight from Ebay. They can be a lot higher if you want to chase them. I find that I can get goos user 4s and 5s for under $25 counting freight, and for as little as $2 to $5 at fleamarkets. Then you have to clean and tune them, but thst in itself educated you on the tool.
Joe
Of the countless numbers of hand tools that I have. I can count on less than one hand the new hand tools I've bought. Flea markets, garage sales and antique stores provide all my needs. And It's a lot of fun rehabbing an old tool, getting acquainted with it, thinking about where its been and what its done and getting a little of its history when you can. Like the previous owner or further back. Old tools deserve a better life than the land fill and a little loving and use too. Make them happy as well as yourself.
Bruce S.
Thanks for the replies. Another question, what is junk what should I not buy?
Zabo2
Zabo,
Stick with Stanley, Sergeant, Millers Falls, etc. Avoid Anant and new planes this side of WW-II in general. I would highly recommend you visit Patrick Leaches Blood & Gore WEBsite to get a real good understanding about old planes.
Here ya go: http://www.supertool.com/StanleyBG/stan0.htm
Zabo2,
Brands you should avoid when buying a bench plane:
Dunlap, Shelton, Fulton, Stanley Handyman, Stanley Defiance, Buck Bros, Great Neck, Corsair
Brands you should look for:
Sargent, Millers Falls, Stanley Bailey, Union, Craftsman, Lakeside, Wardmaster
Brands you can buy but will probably fetch collector prices:
Stanley Bedrock, Stanley Four Square, Record, Vaughan & Bushnell, Siegley, Keen Kutter, Winchester, Clifton, Lie-Nielsen, Veritas
mike
Edited 5/30/2008 2:54 pm ET by mvflaim
Zabo,
Look at this site: http://www.brasscityrecords.com/51.html
Walt is a good guy and he won't sell you junk.
Good luck,
-Chuck
