I’m not sure which diameter air hose to buy the 1/4″ or the 3/8″? I’m will be using it for my nailers and other air tools, would I see a difference between the to?
All of my hoses are tools use 1/4", can't really imagine using anything bigger unless running several hundred feet of hose or something like that. Only time I ever saw 3/8" used was where they used it to run maybe 300' from truck mounted compresser to a manifold that split into four to six 1/4" hoses for roofing nailers.
In my shop I used 3/4" pipe from compressor to several regulators in handy locations, then 1/4" hose as short as I can get away with. 1/4" has several advantages: easier to get in a bigger variety of fittings; lighter weight that adds up if you pulling around that bigger hose; lower cost due to availibility; most tools come standard with 1/4" fittings.
ParCap-
Unless you are using a 3 1/2" framing nailer, 1/4" hose is plenty. Keep one thing in mind with the flexsteel hose: try not to work in a circle. I have a tendency to turn in only one direction while I work, so the hose turns into a pretzel in no time. Other than that, I love the product.
Sean
An HVLP conversion gun will probably be happier with the 3/8".
Edited 3/11/2007 11:55 pm by polarsea1
I use the 1/4" Flexeel on everything -- even framing nailers.
One tip though: buy the 25' sections, even if you are looking for a longer hose. The shorter hoses are much easier to coil/uncoil than the longer lengths, and it is no problem to join them together for whatever length you need.
I assume we're talking about the straight hoses (and not those which are pre-coiled).
John Wooden 1910-
