I am looking for ideas on a flip top vacuum press. Has anyone out there built one? I am currently using a bag with a 10 cfm pump but the bag is a little slow and cumbersome to load. Unfortunately the cost of a commercial unit is not easily justified.
Tom
I built a top-loader, but eventually trash-canned it. It was convenient to use, but a bear to store. It was big enough to veneer a 4x8 sheet of plywood. That meant it was nearly 5 feet by nearly 9 feet. That's a big object to store. In contrast, a 5x9 bag rolls up into a much smaller bundle -- one that can store up in the rafters, or high on a wall, or wherever. If I had a shop with unlimited space, and/or if I were doing veneering every day, the top-loader would make more sense than a bag.
Jamie,
How did you fabricate the frame and what did you use to seal the frame to the table? I have set aside room in my shop for a dedicated press that will be out of the way of my bench and machine work, so I am lucky in that respect. This is my forth shop and the only one that was purpose built (my other ones were garages and basements)
Tom
The bottom was a torsion box, covered with 20 mil sheet vinyl. I originally hoped that the melamine surface of the torsion box would be airproof enough, but it turned out to leak like a sieve. The frame for the top was 2x4s with the 4 dimension vertical. The top's 20 mil vinyl was just large enough to wrap up the outside and be captured to the 2x4s by duct tape. The seal was foam-rubber weatherstripping, stuck to the underside of the upper vinyl. It was something like 3/8"x3/4" cross-section, with peel-and-stick adhesive on one face. It was called closed-cell foam. It came from the local borg. The top was held to the torsion box with a raft of woodworkers clamps. In operation, the torsion box sat on sawhorses, and the tent was suspended from the shop rafters with a pulley arrangement, so I could drop it quickly on to the torsion box.
With that long of a seal, there's more leakage than in a bag of the same size. I have a 5 cfm vacuum pump, and it would run pretty much continuously.
Edited 9/5/2007 10:34 am ET by Jamie_Buxton
