Floor Standing Drill Press Recommendations
I am a hobbyist woodworker in a small home shop. I have been using a Delta bench top drill press for a long time. Still works, but limited in capacity and features. It sits on a cart that takes up more room than a floor standing press would. I would like to free up some space for other uses by eliminating the cart and upgrade my drill press capabilities with a smaller footprint.
I am looking at the Powermatic PM2800B. Features look good. But performance and build quality reviews are mixed. I don’t have experience with Powermatic tools, but have always been under the impression that they are solid and perform well.
I’d be interested to know your experiences with this model and your recommendations for alternatives. The price of this model is right at the upper limit of my budget ($2200).
Thanks in advance for advice.
Russ
I went through this about 2 years ago. My number one requirement was variable speed - i.e. no belt changes. It came down to the Nova Voyager DVR 18 In., the Powermatic you referenced and a Grizzly milling machine on a drill press stand. I eliminated the Grizzly due to the weight (over 700 lbs). I then eliminated the Powermatic due to the consistent negative reviews on the "Mechanical variable speed drive". Lots of issues with noise, belt slipping and buildup of belt debris as I recall.
I'm very happy with the Nova. Some reviewers reported issues with runout on the spindle but I checked mine with a dial indicator and it seemed fine.
Since then, Powermatic did come out with an electronic variable speed model (PM2820EVS). It's more expensive ~$2800, but worth looking at.
Hope this helps.
It does help. Thanks.
I hadn’t looked at the Nova but now have. It looks like this could be an attractive option and closer to my budget.
Most of the reviews are very positive, better than the Powermatic. The recurring negative comments relate to the chuck limit on holding small bits, the display (too small and too dim), lack of task light, and poor machining of the table.
Some reviews are old and the current model may be different. Did you encounter any of these problems? If so, did you have work-around’s for them?
Russ
Hi Russ,
I think the smallest bit I've used is 1/8 in. so can't really answer the small bit question. Chucks are easy to change though so that might be an option if using really small bits becomes an issue. A keyless chuck might be worth considering.
I use a magnetic light on the side, but I agree an integrated light would be nice. I didn't notice any machining issues on the table but I've covered mine with a "woodworkers" drill press table with a fence and replaceable inserts.
Dean
Thanks Dean. I also don't often drill holes less than 1/8". A keyless chuck might be an add-on later, on but normally I can find the key, so not a big deal.
You have helped me clarify my thinking on this major purchase. The Forum is a great resource for this kind of advice.
Russ
About a year ago I had the same question. What floor mounted drillpress should I be looking at. My decission was made when I looked at the specs. and the price (and of course the reviews). The Delta 18". The belt speed is very easy to adjust,integraded light and the quill stops are great. Price was good for a press that offers so much. just under $1500. Take a look at this model, it might be just what you could use in your hobby shop.
For that money you are looking at my dream drill press the Nova Voyager.
It's hard to walk past such a well-featured machine.
Sadly I've only ever played with one in the shop (sigh...) but it's a comprehensive piece of kit.
https://www.teknatool.com/products/drill-presses/nova-voyager-dvr-drill-press/
I have the Nova Voyager DVR, and couldn't be happier.
Q on the Nova... How is the table height adjusted? I don't see a crank in any of the photos. (Also considering an upgrade)
It's a traditional crank height adjustment.
I went with the Nova Voyager. Thanks for very helpful recommendations.
Russ
