I have an issue with three possible solutions. I’ve just finished two drawers with 7/8″ cherry fronts & 5/8″ sides (maple). I chose half blind dovetails to contrast the maple to the cherry. Everything has gone well. I glued them up this past week-end and started fitting them tonight and noticed an error. I made the tails (sides) set into the pins (front) by a fat 32nd. This was with the assumption of using a flush trim bit to nock it down flush. Done it many times without any issues. Well while fitting the drawers tonight I noticed when I cut the fronts to match the opening, I measured without making allowances for the offset of the tails and now if I take it flush my opening will be almost a 1/16″ on the sides. I could either go ahead a flush it accept the fat opening and make the top & bottom match and live with it or, I could flush all the way except the last 3/8″ or so and that would leave me flush on the dovetail and a tight 32nd on the sides a top (which I usually do), or the last option is leave the tails recessed and the pins fat to the sides and have a fat 32nd opening around the drawer front and not worry about it. If you had this what would you do ?
I dunno if I followed all that, but assuming I did, I prefer leaving the edge like this:
Sorry putting it in words was complicated, but basically the pins stand proud of the tails. cutting the sides flush with the tails would leave a full 1/16" opening. Hopefully that makse since. Nice work BTWGovernment's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
I understand this to mean your drawer fronts will be smaller than you want.
Fix #1: Can you glue a thin strip of veneer around the opening in the carcass? If you can't match it seamlessly, perhaps use a contrasting wood to accent the opening.
FIX #2: If you want a bigger accent (like a cock bead) cut a rabbit in the carcass frame and glue a wider strip into the rabbit. (If the rabbit is 1/4 inch, glue a 5/16 or 9/32 strip into the 1/4" rabbit).
Fix #3: If you haven't glued the drawers together, put a small spacer behind the dovetails on the sides. It will only be visible from the insides of the drawers and only to someone looking for it.
I'll bet there are at least 3 other options too.
Greg
Exo 35:30-35
Edited 5/19/2009 7:57 am by Cincinnati
Here is one solution:
http://www.taunton.com/finewoodworking/ProjectsAndDesign/ProjectsAndDesignPDF.aspx?id=2646
Here is a case where he just cuts the proud pins down and leaves the front "blind" edge proud :
http://www.taunton.com/finewoodworking/SkillsAndTechniques/SkillsAndTechniquesPDF.aspx?id=2730
Hope one of these gets you out of the woods.
roc
Bones,
Have you considered adding cock beading to your drawer?
Bones,
My suggestion is to pare the pins flush with the drawer sides with a chisel, then bevel the drawer front's ends down to come even with the ends of the drawer sides. Using a chisel, pushed in from each edge of the front toward the center, takes only a few seconds, I've done this often.
I think I understand what you are saying leave it full lengh at the front edge and pare it back (taper to the tails), correct?Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
bones,
Correct.
>cock beading draweror>leave it full length at the front edge and pare back the pinsthat was the gist of the articles i posted. They have good detail for how to go about this.rocGive me six hours to chop down a tree and I will spend the first four sharpening the axe. Abraham Lincoln ( 54° shaves )
I feel I have a way forward now, thanks again to all who helped. Government's view of the economy could be summed up in a few short phrases: If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.
