Hi,
The local football league is looking for around 50 feet of base cabinets,all big drawers, to store football pants and assor stuff. I will be donating the labor the material is on them. The only requirements are; good full extension slides, NO particleboard or MDF, and the drawers as big and deep as possible.
I plan on making them out of birch, maple or AC fir, what ever their budget allows. The construction and “design” is up to me. I will make the boxes the same as a standard kitchen with a separate “base frame” to raise the boxes up the height of the kick. I am going to build these in my shop in 4 ft sections.
My question is do I put face frames on these?? If I go frameless how do I seperate the units in 4ft sections to move?? Do they need backs or just an angle brace? If I go with face frames they do not want to “hang the slides” do I have to cut all those spacers??
Any input would be greatly appreciated
MikeD
For a run of cabs of that length, I think your job will be way easier to go frameless. Yes, you would need backs -- but 1/4" luan will do, and I would do do full overlay false fronts.
If you have someone to help you move these things around, 4 footers will work. But again, the job of making all those cabinets would be easier if you built them in 2 ' units, even though materials cost would be higher. Use 1/4 - 1/2" spacers between each cab -- perhaps paint them black for a sharp, contrasting look no matter if they are painted or natural finished.
I assume you know about settling on a design, then gang cutting the whole shebang -- and assembling them as your space permits.
Kudos to you for volunteering to take on this large task. I only hope they will appreciate how much effort it will require from you.
What do they have against particle board/MDF?
These cabinets are going in a walk-out basement of sorts, and therefore they want no mdf or particleboard. Your idea of 2 foot unit does sound alot more manageable and would only cost 2 sheets or so of ply, I may go with it.
The only problem with the frameless is edgebanding all the ply, I will most likely will go this route though.
MikeD
Edited 11/16/2004 4:00 pm ET by MikeD
Given the abuse that these cabinets will take I don't think you can go overboard on the materials. I would go with 3/4" BB Ply and base my module for economy on a 5 x 5 sheet. Secondly I'd go frameless but with solid wood edge banding. Wood tape just won't hold up. I'd use 150# Blum, Accuride or KV full extension slides.John O'Connell - JKO Handcrafted Woodworking
The more things change ...
We trained hard, but it seemed that every time we were beginning to form up into teams, we would be reorganized. I was to learn later in life that we tend to meet any new situation by reorganizing; and a wonderful method it can be for creating the illusion of progress while producing confusion, inefficiency, and demoralization.
Petronious Arbiter, 210 BC
<<"walk-out basement of sorts">>Does this mean the cabinets will be exposed to moisture?If the cabs are going to be painted, one of the beauties of MDF (aside from cost) is that you can get an acceptable finished edge without covering it.
The room they will be in has not had any "flooding" but it is a basement, with 2 large overhead doors in the next room, and they did have a dehumidifer running in the next room also. This space will not be heated in the winter, so these cabinets will be subjected to a few temp swings.
I like the idea about BB, I may try to lay them out on a 30" module.
MikeD
MikeD,
My one experience with a large cabinet made from BB Ply did not paint up very well...the sides looked like planer snipe. Perhaps I did not select the stock carefully enough but the sheets are so thin I'm not sure if the paint caused the issue..anyhow, thought you'd like to know
Mike,
I'd go with the AC Fir plywood. It is a heck of a lot cheaper than Birch Ply and from what I can tell these cabinets are strictly utilitarian. If you brush them with a couple of coats of poly they should be able to perform for many years.
J.P.
