You should try it. I’ve been using it for all my finishes including paint for about 6 months now. I would say it’s almost as important to me now as a jointer or planer. Frankly, I am amazed that I got along without it.
It doesn’t take much to learn how to use one and there are lots (well, at least 4 so far) of waterborn finishes that look great. Really, really easy to clean too.
The sooner you get started, the gladder you’ll be.
Bill
Bill
What kind did you buy, been thinking that I need one, hate having to hire it out all the time.
Doug
I bought the gravity feed Porter Cable thinking I'd try it and get a more expensive one if I needed it. It works fine so far. I did buy the 1.3 needle and tip though, and that's what I use on almost everything. It's packaged with a 2.5 or something like that. I can't imagine why.
I bet you'll be getting fine results in an hour or two. I can clean it in 5 minutes.
Feel free to ask any questions yoiu might have.
Thanks Bill
I will have to look into it, dont know anything about them so no questions right now, but I'll keep you in mind when I get one.
I know I need to get one, cant keep counting on the finish guy that I use to get the work done when I need it. Hes starting to doubt me when I tell him that I need it done today, cant say that to many times.
Doug
Ah... it's a gravity gun. That explains it. LOL
My first exposure to HVLP technology was a conversion gun on a pressure pot. I didn't like it. But, then I was exposed to an HVLP gravity gun and having becomed accustomed to using them... I can totally related to what you said in the first post. They really are a fantastic piece of equipment. They have their drawbacks. But, man.... do they spray sweet!
Kevin
The 2.5 needle is ment for heavy bodied finishes. A pressure pot will spray these type finishes better than a gravity or suction gun without excessive thinning. A pressure feed will also spray at most any position without fluttering. I know, I have both and prefer the pressure feed.
I would have thought so too, Tom, but I'm spraying everything with the 1.3 including latex wall paint (thinned 10%).
I may go with a pot some day but don't need the extra capacity yet. I would like the ability to hold the gun sideways/upside down etc. though.
The PC drips occassionally. Say every 10th use a couple drips per fill. I'd like to figure that out. I would say that's the only problem I've encountered.
Bill
That's good to know. I never had that good of luck with using latex or acrylic out of a gravity or siphon gun.
The drip could be caused by dried material build up on the needle/noozle assembly. Had that problem with acyrlic until I started taking the cap off and cleaning the nozzle and needle after every couple of 2-qt pots. It could also be caused by crap in the paint. If you don't strain, you may want to start doing that and see if it stops the drip.
Hi, Bill,
Since seeing your post I started looking onto the gravity feel PC sprayer...is it the PSH1 you got?
Seems my compressor is a bit wimpy to drive this thing, so I'm looking for suggestions on a good, all around compressor for light use. I don't do sanding with it, but do drive brads and small nails, and use it to blow dust out of stuff. Up to now, the little 1HP Porter Cable pancake compressor my wive gave me as part of the brad mailer kit has done fine, but it's probably time for an upgrade.
FWW had an article in the latest issue on this subject, but they're suggesting more than I think I need. What compressor a reyou using and what might I get away with?
Thanks!
Lofton
I'm using a PC 20 gal and another older 20 gal on site. The PC runs at 165 PSI and handles the sprayer very well. The other one probably operates at 125 psi and does fine. Both are oilless. Good luck.
