I have heard of some kind of material that is inserted unseen into the slot of a frame of a frame and panel door to keep the panel from moving TOO easily. I find that if a frame and panel door is stained in finishing, there is a danger of the panel moving and allowing the unstained edges of the panel to show. Of course, I understand that one cannot SECURE the panel in place to allow expansion and contraction.
Does anyone know of the “filler” material I mean?
Most of the woodworking stores and catalogs carry "Space Balls". They're pliable enough to place into the dado and compensate for any expansion or contraction.
Len
CMT makes there own it called panaline ( I think) it looks a ittle like weather stripping. I havent used it just answering your question :)
Darkworksite4: When the job is to small for everyone else, Its just about right for me"
Edited 5/16/2002 11:21:36 PM ET by Ron Teti
These spacers only keep the panel from rattling in the frame - it will still expand/contract and will still show unstained edges. If it didn't do this, the rail/stile joints would fail.
The only cure (that I know of) is to pre-stain/finish the panel edges prior to assembly.
1999 Cherry/Ivory Roadstar
SCRC #241005
ISRA # 8601
For my panel doors I used the plastic spline material used in screen window and door frames. I cut a piece 2 inches long and cut 1/2 way through it so that it would bend easily at the corner. 4 per panel.
