Freud Diablo blade vs. Freud Ultimate
Is there a difference between the Diablo Cross Cut blade that I find at HD and the Freud Ultimate Cut Off blade – both 10″ and I think the same number of teeth. Do they have different red coating? I tried the Freud site but couldn’t find a way to contact them.
If the number of teeth is the same, then check the kerf and the coating. The HD near me stocks mostly the thin kerf blades. I have a diablo that is gold and the ones they have now are red - but I don't think they are the same red teflon coating that is on the ultimate cutoff blade. I have not been that happy with the thin kerf blades except for ripping.
Thanks for the reply. I've got an Ultimate for my slider and I am thinking about getting one for our Habitat saw. Don
Thanks for the reply. I think the coating is different on the two blades. I've got an Ultimate on my home slider and am thinking about getting one for our Habitat saw.
Don
I have the Ultimate Cutoff Blade (LU85). The difference between it and their other cutoff blades is the difference in amount of side clearance. In loose terms, how much the edges of the teeth "stick out" from the blade body, which is only .009"
I can testify that this blade does make a "glass smooth" cut. It's absolutely amazing! A possible downside to this design is that if a piece of wood had some internal stress that would make the kerf close slightly upon crosscutting, binding would be more likely to occur that with a regular blade. For that reason, they offer the LU85 in a Teflon coated version, which is the one I have. Since the project I bought the blade for involves stock less that 3" wide, I wasn't concerned about the binding.
The other downside is that if you needed glue to adhere to the end grain, you'd probably have to sand it! That's how smooth the cut is. However, we all know that glue isn't great on end grain anyway.
If you want extremely smooth, accurate crosscuts, the LU85 is a winner, but I'd expect the Diablo to do an excellent job also, just not as polished as the LU85. I'm not a big fan of the Teflon coating, mainly because it comes off so easily, and I haven't needed the slickness that it provide.
Edited 3/15/2003 11:28:33 AM ET by forestgirl
