Has anyone had any experience with a Freud panel raising bit? I am setting up to make some raised panels with an arched top. I’ve been back and forth with Freud tech support and they are saying you should run the panel on the pilot. Most bits with backcutters have bearings in between, but this one doesn’t. Does anyone have any experience using a bit like this in this way?
I've not made arched top panels, but I have used Freud panel raising bits (most of my other router bits are from Whiteside). I've been very pleased with them- for panels I run them in a PC 7518 @ 10k on a Veritas table. No problems so far...
Glaucon
The Freud raised panel bits with backcutters are intended to be run with the solid pilot portion of the bit that is between the cutters against the material when routing arches. This can cause some slight burning but the edge of the panel is hidden in the groove so it will not be a problem. If you wish to make multiple passes remove the backcutter and lower the bit some. Then raise the bit for the next passes until the desired finished heght is reached and finally reinstall the backcutter for the final pass.
Edited to add::
The Freud RP w/BC bits are the only ones that will cut a full 1-1/2" reveal. The design is patented which is why you don't find it on competitors bits.
Freud America, Inc.
Edited 8/24/2005 8:09 am ET by CharlesM
