I’m planning to finish a banjo rim using friction polish, same as the friction polish used by the guys who make pens. I don’t see too much difference, other than the obvious one which is that the banjo rim is MUCH larger in diameter than a pen. I was wondering if anyone has any tips or suggestions.
Is the banjo rim that you want to finish still mounted on a lathe? Thats where the "friction" derives as finish is applied while the lathe is spinning. A bit more about what exactly you are hoping to achieve might be of benefit.
It's not on the lathe now, but can be returned to the lathe and that was my plan. I'm looking for a thin, easy to apply finish. I tried earlier and didn't like the result. The finish was fraught with hills and ridges. I suspect, that unlike a pen, the larger diameter lets the finish dry before completing the revolution. As this happens multiple times, the hills and ridges form.
