Does anyone know where I can buy a frog adjustment screw (the one that screws into the bed of the plane to move the frog in or out) or what thread they normally are? I have a vaughn and bushnell #905 that has that srew snapped off inside, once I remove it I might have to retap it. any help greatly appreciated thanks rb
If you can measure the thread pitch from the stub you extract, then it won't be to hard to find the correct screw/bolt to replace it. Other wise you can measure the hole to get the same. You may have to make a nice knob for it, but it should work.
Hi RyanC I recieved your mail yesterday and it is a perfect match. I just wanted to let you know how much I appreciate it. If every anything I can do for you just let me know again much thanks Rick Barlow
Don't worry about it. I'm just glad it matched.
-Ryan C.
