I have been slowly getting into woodoworking as a hooby ever since I moved into a house that had a basement large enough to house my grandfathre’s old equipment. As I layed out my shop on paper, I came across Alan DeVilbiss’ island workbench article in the 2006 Shop & Tools issue. I recently came into a 12′ x 4′ section of bowling alley. At first glance this seems like a good choice surface to build my island bench upon. I just wants some feedback and opinions on whether a bowling alley would make a good work bench surface or not. Any thoguhts?
Wow
How does one get a hunk of bowling alley? Don't know how well it would work for a workbench but if it is bowling alley it must be flat. Might work for other things like assembly table tops and such. How thick is it? What kind of wood? I know bowling alleys throw out used pins on a regular basis, do they also do that with flooring too?
Yes, It Will Work
The Bowling alley section will work just fine. However, if you need to cut it in length or width be careful of hardware inside of it.
On all the bowling alley sections I have ever seen, small sash pins about 3/16" x 1-1/2" were used to hold the laminations together and aligned while the assembly was put into the clamps. These pieces of steel will really get your attention when you cut into them. They are scattered throughout the glue-up, so there is no predicting. A metal finder may work. Thery are not used on the outer plies.
I just use junk blades, wear glasses, and go to work.
The Maple alley will make a superior bench top.
Dave S
AcornWoodworks.com
Strike!
Hi Dave,
There is a salvage place about 40 miles from me and they have many sections of bowling alley. They will size it for you for $25, and you buy the blades. Can't remember the price for the sections but as I recall it was very reasonable.
So what is it
so what is it with all this bowling alley scrap. Does it have to be replaced often or is it just the first 30 feet where the ball lands. I know 30 feet sounds like a long throw but you havent seen me bowl.
I dunno
At least in this neck of the woods it seems like bowling's popularity has declined significantly. When I was growing up there was a bowling alley right close by and we used to bowl quite often. Candlepin bowling was quite popular, actually that was the only kind within 50 miles. Very few alleys still around, again, in this neck of the woods anyway.
Nice Find!
That will make a great workbench or even a large kitchen island/chopping block. But as stated earlier do we careful of fasterners within.
Workbench top
My assembly table/work bench is a bowling alley top, just over 8' long and love it. I have it backed up to my tablesaw and use it as an outfeed table, so it serves dual purpose. And Yes they are FULL of nails as previously mentioned.
My section is a "down stream" section, Southern yellow pine.
Down Stream
That's interesting. I always assumed they were 100% maple the entire length. Now you have me wondering...
I assumed the same thing about maple. I did a sight unseen trade for the for the length of bowling alley and made a 45 degree lock miter base pedistal that was tapered vertically for the guy, 2' X2' X 38" out of 3/4 " oak ply. What a let down. But the SYP is still a very good top as 90% of the lumber is pretty much 1/4 sawn.
I have a bowling alley for my main bench and a rolling bench with my lathe in it. The only problem with using bowling alleys arethey need to be flattened. Alleys have a crown built into them. I planed mine flat with a Stanley #6 and a lot of elbow grease. I also mounted an Emmerts Pattern vise on the main bench along with a rapid action vise for the tail. I've had this setup for about 30 years, and it's the heart of my shop.
TX PS
I KNEW IT I KNEW IT !
That crown was the reason for all those gutter balls. Thanks for nuttin, bowling alley people.
Bowling Alley Workbench
They're great workbenches. The one I got was nailed, I cut it to length using cheap carbide blades (wear safety glasses), then split off what I needed for the bench. Keep the angle irons or make cleats across the underside to prevent warping. About the first 1/3 of the lane is good, rock maple, then pine, then more maple where the pins fall. Even the pine section makes a great assembly bench.
