Front-loading washer/dryer base plans
Hey everyone!
Just wondering if anyone has any plans or has built a base with drawers for the new front loading washer and dryers. They had them at the appliance store, but at $150 each, I figured I could build on for cheaper. The one thing I would really like to know is how much support does one need to put under these things? Those washers are built like tanks and I can’t figure out how much support to put underneath.
Thanks in advance.
Jeremy
I'm making mine 28" square with a drawer. 3/4" maple ply for the box, just standard rabbeted construction, but optimizing so the case top can handle the load (glue blocks in upper corners, sides butted to support the top). 3/4" back adds some support too. Don't forget that the washer itself has feet (I'm adding a pair of vertical front-to-back ribs under the dryer feet). Maybe then you could get away with 1/2" material, but I'm going with 3/4".
I've got a 28w x 9h x 28d box. Sides have edge banding on front edges. Applying 1 1/4" high maple molding to keep dryer from vibrating off top, also covers edges of top ply. Applied max 2" skirt covers bottom edges, looks like wide legs. Leveling screws in 4 corners are real legs. Two ribs 1" in from left and right edges are grooved into top and bottom to add support for dryer weight, hole cut for leg adjust access. Drawer is 24" w x 7" h x 26" d, simple 1/2" ply box. Two slides attached to box bottom. Drawer front is 3/4" maple ply, edge banded, shaped to flush fit in front.
That's my plan, anyway. I'll be watching this thread too, thanks for asking this.
What I'm thinking I may do is similar to what you have just described. I'm planning on making mine 12" high though. Instead of using glue blocks help support the weight of the washer/dryer, I think I may put a 2 x 12 on edge, directly under the legs. I figured that way, all the weight would be supported by the 2 x 12 and I wouldn't have to worry about the top warping or sagging at all. I would rather not have the whole box come crashing down some day. What can I say... I overbuild. I haven't quite figured out what I'm going to do for moisture protection yet though. I have noticed that if you open the doors right after the load is done, water drips from the door a little. I don't know if it would really be that big of a deal, but...
Thanks for your input though.
I probably wrote imprecisely. The weight in my design is supported by the side being butted under the top, and a 3/4" ply rib under the dryer feet set into 3/16" grooves. The glue blocks are primarily to resist racking.
Not sure my input's worth much, I'm looking for help as much as you are! :)My goal is for my work to outlast me. Expect my joinery to get simpler as time goes by.
2X4's, 3/4 ply and some nice enamel paint?
