Has anyone used Fuhr waterbased products? I’m looking at the 260 urethane to spray cabinets. Thanks.
hi,
I recently used
Fuhr waterbased poly on two projects and got a bit of cloudiness in both of them. Not sure what happened, but Im going to switch to general finishes.
thanks,
Stevo
I spray Fuhr 355 and 380 often and never have a problem. I actually love the stuff because it levels very well and is so easy to clean up. Make sure you use distilled water when thinning.
I have read many books and articles on finishing, but I have never heard of using distilled water. Out of curiousity, why is that important? Thanks for your input.
In my case I have well water and there are a lot of minerals in that water. I assume this is why it is recommended to use distilled water, just as it's recommended NOT to use steel wool between coats because the steel will rust.EDIT:
I can't recall where I read to use distilled water for the Fuhr but Target says to use distilled and that's basically the same stuff:
http://www.targetcoatings.com/oxford-brushing-varnish-tech.html
Edited 1/7/2007 9:34 pm ET by Mumda
I knew there was some logic to it somewhere, and your explanation makes sense. Thanks.
In 'Waterborne Finishes Come of Age' in FWW #187, Chris Minnick's article has a table which implies that Fuhr 355 Acrylic Varnish has 'Transparent' clarity and 'Clear' color. Jeff Jewitt's site describes 355 as 'A slight amber tint (#355)...' and further in the description: 'Use the water-clear version (#375) when you want a clear and non-yellowing finish'. Then in the description for Fuhr 380, it says 'This is the water clear version of the 355 above'.
So, I'm confused. The article says 355 is clear and transparent. Jewitt says it has an amber tint and says 375 is the clear version but then goes on to say that 380 is the clear version.
I'm very interested in the Fuhr because the FWW article gave it very high durability ratings and I want to use it for a dining table top. But, I also want a clear non-yellowing finish. I don't know which Fuhr product (355, 375, or 380) will do that, however.
Any insights?
I've only used 355 and 380. 355 does have a SLIGHT amber tint. 380 is true water clear, and it says so on the can.Check out Fuhr's website for more info:http://www.fuhrinternational.com/main.html
I've used Fuhr's No. 355 acrylic varnish. It's easy to spray, looks nice and is durable.
For more information on Fuhr Finishes, you can check out Jeff Jewitt's website at http://www.homesteadfinishing.com. If you don't already know, Jeff writes articles and books about finishing, and this is his website. He sells finishing products, and has a forum there. You can actually ask specific questions about it, and get real good answers to compare with the real good ones you'll get here! BTW, he recommends Fuhr finishes.
