Good Morning!
I need help locating some hardware…if it’s even available.
I need help finding hardware – if it’s even available.I am building an entertainment center with full overlay doors. I would like to use the sliding hardware to conceal the doors within the carcass. Does anyone know of a source for full overlay sliding door hardware? Or a way I can configure the common inset sliding hardware for use in an overlay situation?
Thanks!
I'm having trouble reconciling "full overlay" with "conceal the doors within the carcass." I can't picture what that would look like.
If the door is full overlay, it would be too large to slide into the opening.
I really feel uncomfortable about using these words, because you never know, but I do believe that "it can't be done". You've got a contradiction in terms. By definition, the door overlays the cabinet size and therefore cannot fit inside it at the same time.
David Ring
David and All ,
I've seen those listed in the specs but have never used the overlay feature . Looks like the pivot point or aspects of the system are modified like your trick on 3/8" lipped with standard parts Euro hinges .
A new trick for old Dogs .
dusty, The angular box maker
Yeah, the pivot point can be gotten to work, but a full overlay door is taller than the cabinet. The height can't fit inside...
David Ring
I think when they say full overlay , the edges fully overlaying , not the height is what they are talking about .
What happens as you know , is the pocket doors become flush / inset , and sometimes the other doors or drawers may not be inset . This edge overlaying feature can allow say, a pair of doors over another pair. 1/4" horizontal reveals , they would look the same , without being inset .
Hey David how are you at angular cabinets ?
dusty
Hi Dusty,
Well, I've done some nightmare angular cabinets at times. We did a huge job last year for offices in Manhattan that had a 15' run of cabinets which was angled at 7° - the top sloped down at the same time that the depth of the cabinets decreased continuously by 7° ! Since it all had to be taken down and shipped in pieces, it was quite a headache.
What've you got?
David Ring
David ,
Over the years I've built some angular stuff as needed , this started out a normal entertainment corner tv sectional ,,,except it changed into a say 48" wide tall cabinet set diagonally across the corner of the room , then one of these little strangeozoid shaped cabinets on each side .
It did take some head scratching but the hardest part is bout over , ready to glue the faces to the boxes .I glued the angle face members before assembling the face,the wood is still in a rough state in these photos.
dusty
How about these?
http://www.leevalley.com/hardware/page.aspx?c=1&p=48629&cat=3,41305,55408&ap=1
If not, suggest you check out Hafele or Hettich to see if they can accommodate.
Good luck
Hmmm...
I guess the "full overlay" as described in my first post relates only to the hinge side of the door overlaying the cabinet side 3/4". Sorry to confuse things with poor descriptions.
Brad805,
The desciption by Lee Valley in the link you posted is a bit misleading because it mentions full overlay hinges, but is used for "inset doors only." These are the hinges and slides I was going to use, but then after closer examination realized they were for inset doors.
After some more digging with Google I found these...
http://wwhardware.com/catalog.cfm/groupid/Pivot%20Door%20Hardware/catid/KV8091%20Full%20Overlay%20Heavy%20Duty/showprod/1
Has anyone used these before? Or have another brand to recommend?
Thanks!
"The desciption by Lee Valley in the link you posted is a bit misleading because it mentions full overlay hinges, but is used for 'inset doors only.'"
You might want to check with them, because I think these may be what you want. Your doors are "overlay" on the vertical, hinge-side edge, and "inset" on the horizontal, top and bottom edges. When LV says that they're for inset doors, they may be referring to "top/bottom inset" rather than "inset all the way 'round."
Edited 9/14/2007 1:37 pm ET by saschafer
