Hi,
My name is Peter and I live in NH. I have subscribed to FW for more years than I can recall and look forward to every issue. I recently discovered this BB and after looking around, decided that you have a knowlegable and (more important to me) courtious group. So here I am.
Now that my kids are almost grown, I decided to pursue a long held goal, building furniture using traditional methods for the most part.
My question:
I recently picked up a jointer plane marked Fulton. I am curious about the manufacturer. The web hasn’t given me much info other than one brief reference about Fulton being a line of tools sold by Sears during the 50’s. If true that would mean that another company(s) made the tools and put the Fulton name on it. I think Sears has always been a reseller.
Can anyone shed light on this mystery?
Peter
Peter -
I have 4 Fulton paring chisels and have seen Fulton smooth planes. If they came from the 50s or 60s a good bet would be that they were made by Miller Falls or Sargent.
Good luck on pursueing your goal!
Rich
Thanks Rich.
I wonder if Stanley may have private labeled. Mine sure looks like a Stanley.
Peter
Peter,
Yes, Stanley was an OEM. They manufactured planes for Montgomery Wards, Sears, and a few others. Fulton does ring a bell and I do recall a discussion on this. I recall that Stanley also OEMd for Fulton, perhaps Larry Williams will see this and verify....
Dano"Form and Function are One" - Frank L. Wright
You are right, Stanley did make tools for private labels not sure if Fulton was one of them though. I will check some of my books to see if I can get some more info for you.Scott C. Frankland
Newfoundland Wood Worker
There's an easy way to tell who made your Fulton plane. Stanley planes that were made for other retailers have a twisted lateral adjustment lever. Instead of the two-piece Stanley lateral lever these will have the flat portion twisted at the handle. Sargent used a stamped lateral adjustment lever that was bent to an upside down U shape. While a couple other makers used this configuration, I believe Sargent and Stanley made planes for Sears. Most Fulton planes I've seen were made by Sargent but they'll use a Stanley style iron just fine.
Bingo! Upside down "u" shaped, stamped lateral adjustment lever. Sargeant is the maker.
Thanks to all who replied. I was hoping someone could point me in the right direction, and you solved the mystery! I am impressed.
Thanks again,
Peter
