What is the proper moisture content for furniture grade wood?
As an industrial buyer I always specified 6 to 6 1/2%, but for custom work at home, it just has to be in equilibrium with the surroundings it is going to live in, to minimize movement. That could be anywhere from 4 to 15%, depending on location and climate.
If you can buy it anywhere from 6 to 10% and give the rough cut parts some time to stabilize before cutting to final dimension, you should be OK.
I know there will be different opinions on this, but that's my story, etc.
Michael R
Thanks, Michael!
I was given 1M BF of 4"X 8" to 16" Pin Oak, three years ago and was told to let it cure. Now I want to use it but was unsure if it is ready. I bought a meter and it reads 16%. Should I bring some into the shop and let it dry under better conditions?
Larry
Pretty nice gift!
The rule of thumb for air drying is 1 year per inch, but it depends a lot on where the wood is. If it were mine, I'd bring some of it indoors and maybe mill it closer to the sizes I was going to use. Watch out for checks and shakes in oak that thick. Thick oak is notoriaously hard to dry in kilns; I don't know how it does when air drying,
Michael R
Edited 3/17/2005 8:59 pm ET by Woodwiz
