I am preparing to use Arm-R-Seal to finish my table soon and have some questions. I always get nervous at this point as the finish can literally “make or break” a piece.
1) I was looking for some tried-and-true advice/steps regarding the application process. The common steps I’ve read so far are apply 2 thin coats within 24 hours, let dry, sand w/ 320, then apply # of new coats and sand in between.
2) My apologies for such an ignorant question: Can Arm-R-Seal be applied with a “bristle” brush or has it been designed for application primarily with rags/towels or foam?
3) I have read for other types of finishes that it’s recommended to thin the initial coat by 30% with the appropriate thinner to aid in settling and adhesion. Would this be adviseable for Arm-R-Seal?
Thanks for everyones feedback!
Z
Arm-R-Seal is a thinned wiping varnish so it is already as thin as it should be. You can brush it but you will generally end up with a better finish if you follow the directions on the can. Your process sounds about right. However, if you apply subsequent coats within 12 hours, you do not have to sand between coats for adhesion. You may want to sand to flatten the surface.
Thanks Howie
Does anybody else have an opinion based on experience of Arm-R-Seal?
Z
Search the archives. It has gotten some favorable reviews. I am trying it now on cabinet doors for my kitchen. I'm not far enough along to offer a legitimate opinion. However, I am giving it a chance because of positive comments in older threads.
Cheer
Kyle
Personally I don't find it much different from thinning any poly varnish 50/50 with mineral spirits. Both will get you to the same result.Howie.........
I used it to finish the wood countertops I made last year in walnut and rock maple. My wife loves the looks of it and it is virtually idiot proof to apply. We used the semi-gloss version which leaves just enough of a shine for our tastes.
Kell
