Oil Finish
You can sand raw wood up to 180 - than wipe on and wipe off your finish oil coats for an in the wood luster. You won't need to sand any applications of oil. It will be smooth.
SA
I'm surprised that they recommend going to 120 only. On hardwood like cherry, I would go to 320. That's fine for an oil finish. It will be important to wipe off any excess oil after letting soak in. Otherwise you end up with a gooey surface of coagulated oil. No sanding required between coats, and don't raise the grain with application of water. You would only do that if you were planning to apply a water based dye, and you are not doing that.
Tim
