Hi All,
Sometime within the last couple of years I saw an article ( I believe it was in FWW ) on how to take a picture of a piece of furniture and extrapolate thedimensions from it. I’ve been looking high and low for this article with no luck,
If anyone remembers it and hopefully the mag it was in, or has a link to such info, please let me know.
Brent
Brent,
Take the pic with a digital camera,
then upload the photo onto your computer
(Save in 'My photos'. Download the photo,open, zoom in to roughly fill the screen, then print it on graph paper.
(Graph paper comes in 1/4"-1/2"or,1" squares.) From the resultant composite print, you can deduce all the measurements by simply appling a known chair seat height dimension and extrapolate from there . Ed
Edited 8/25/2005 4:54 pm ET by Steinmetz
Thanks for the info guys.
Ed, the picture I'm using is in a magazine and was taken at an angle. The left hand table leg is 3 3/4" while the right one is 3". While your idea would work with a straight forward shot, in this case it won't. The article I am refering to uses angles and straight planes to extrapolate the measurements from a photo like the one I am talking about.
Butch, thanks for the info. I'm going to have to go over the magazines more carefully again to find what must have been in front of my face last time I looked.
Brent
If you want to be precise though, I have found out that most printers will print in the "X" direction and in the "Y" direction at a slightly different scale. I found this out when taking pics of plane handles to generate patterns. Every image had to be tweeked in the X or Y direction to get the prints to come out correct. At least it was this way for the 3 different HP printers I tried.
Also, if the object is at an angle to the camera, you have to use trig to take that into account.
PW, Never thought about that X-Y inconsistency one could make two prints one with portrait configuration and the other rotated 90 deg's?I recall an article in Popular Mechanics, where if you cut the drawing out of the magazine and soaked the newsprint paper in paraffin oil, then cut and fit in a 35mm slide frame and project it on the wall/sheet/screen/or white paper, you could trace the outlines with a pencil to make an enlarged copy to whatever scale you needed?
it was in FWW in the last year. don't have the issue # handy, but if you have kept your past issues (doesn't everybody?) you should be able to find it.
butch
BrentS
I believe there is such an article in the current WOOD magazine. I know I saw it this week.
FWW issue#170 ''Scaling from Photos''
KDM
The Bill of Rights
December 15 1791
NRA Endowment Member
LEAA Life Member
CRPA Member
Thanks Duke.......that saves me a bit of time.
Brent
Here's a technique I've tried with good success of course it helps when the picture of the furniture is straight on....
I did this with a "stickly" catalog.
They show a picture and publish dimensions.
Let's imagine that the unit was 30" high according to the caption.
Measure the height of the unit in the photo. Perhaps it's 4.5" tall.
Now you have a scaling ratio - 4.5/30 = 0.15. Check this ratio with other given dimensions (width, depth etc.) It should be pretty close.
Now measure some non-given dimension on the photo (the height of a drawer for example) then use the .15 to convert. So if the drawer measured 0.5" on the photo, divide 0.5 by the conversion factor of 0.15. 0.5/.15 = 3.3" Voila. Your drawer should be 3.3" tall.
Do a bunch of dimensions and make some full scale drawings to test your conversions.
You'll need a precise ruler to measure the photos...
HTH,
Mark
Stan and Mark,
Thanks for the info
Brent
I remember that article and though it was interesting. I think that the process is called deminishing lines, or something like that. Have to evtent all the lines to their convergence point and then you can get acurate measurements. As you said the simple "find the scale with a ruler trick" won't give correct measurements if the picture is taken at an angle, especially from a corner as most are. The width will be very off.
MIke
You can compensate for the vanishing point effect... Provided you have dimensions. Using this pic, try an experiment. The table top is 11.75" wide, the length is 72" height is 32" floor to top of top.I believe you have everything you need to compensate for the z dimension (into the paper)If you'd like to experiment, Tell me the size of the legs etc using the method I described above and the picture posted here.BTW I used the Photoshop filter "Stylize, Find Edges" to create the sketched look and I removed all the color information. It makes the photo a bit easier to measure.MarkVisit my woodworking blog Dust Maker
I like Marks theory! I have use something like it for pictures I got from China of REALLY OLD furniture... It works..Well, depends on if you need EXACT dimensions.. I hardly think it is necessary to be THAT exact.. The ratios of sizes mean the most...Just me...If you need EXACT you need a X/Y/Z scale layin' out in the sand like in the Mars Rover pictures...
Edited 8/28/2005 12:54 pm ET by WillGeorge
