I bought a block (4x6x6 inches) of maple burl some years ago. It was completely covered in paraffin to preserve it. Now I am finally getting around to using it, but I don’t know how to get the paraffin off.
I want to slice the block into 1/4″ or thinner slabs to be inlaid into the top of a chest. I may not use the whole block. What is the best way to get the paraffin off? Should I bandsaw my slabs first, and then take the paraffin off somehow? How can I preserve the remainder of the block? And what do I need to do to make sure the inlaid slabs don’t crack?
Can anyone help me? Have you done this stuff before?
Joe
Joe, Try a cabinet scraper to remove the heavy stuff.
If my memory serves me well, Carbon tetra chloride will disolve wax BUT It's considered highly toxic and can no longer be sold. A substertute would be Carbona (A drycleaning fluid sold in super marts.) Stein.
Thanks much, I'll try the scraper method first. Looks like I slice, then scrape.
Hello,
I was once told that paint thinner(mineral spirits) would disolve wax or parafin. I haven't tried it yet. I remember a lot of things that aren't necessary but forget things I need to know. I guess I am getting old. Chuck
It will disolve wax. I don't know about parafin, though. I've never tried it on that. A blend of various Naptha's (basically refined mineral spirits) is used widely in autobody shops as "wax and grease remover". It's used to remove contaminates prior to painting or prepping. It also works on many adhesives, although slowly.
Kevin
Edited 6/25/2003 1:02:35 AM ET by Kevin
You know, I was just assuming it was paraffin--might well be wax. Thanks to you all for your suggestions, and the information about the stuff.
Joe
Parrafin is a mix of alaphatic hydrocarbons (straight chains of carbon atoms with hydrogens handing off to the side, plus a few branches) just like mineral spirits. The mineral spirits chains are shorter so it is a liquid at room temp.
Yes, mineral spirits (paint thinner) will dissolve parrafin, but may carry it further into the wood. I'd scrape and perhaps sand away the parrafin and some of the wood it's absorbed into.
good ole WD-40 will desolve wax also, don't know about parafin.
good luck rg
I don't know how thick this is but you might try softening it with a hair dryer, then scraping carefully while soft--and finally something that would dissolve it.
