Hi Darrell,
Just finished reading your book(nice job by the way)and I was wondering how you create your finger joints when the fingers are around 2″ or larger and the panel is larger, around 16-18″?
thanks for any suggestions,
Hi Darrell,
Hi Jeff,
I am not sure I understand your question. Do you mean when the fingers are 2" long or wide? Are you wrapping finger-jointed solids around a panel?
Fingers 2" long would take some thought. One method would be to flush trim the fingers to a routing template. You would then have to come back and square out the round corners left by the router.
Fingers that are 2" wide are relatively easy to deal with. I used to do all my fingerjoints on the table saw with a dado. If the individual fingers were very wide I would make multiple passes to get the width I needed.
For the past couple of years I have been producing finger joints on the multi-router - in which case wide fingers are not an issue but long ones would again, take some thought.
Let me know if this helps.
Darrell
Thanks Darrell,Yes, the fingers are 2" wide on a 16" wide panel, 3/4" thick, but the fingers are 7/8" long, so they end up 1/8" proud. So with the Multi-router, are you using a template, or how are you getting repeatablity, so the joint is precise? I have no trouble making a precise 2" finger, but getting 4 to all work out across the width of the board has been the issue.Hope this is clear, thanks again,
Jeff,Thanks – yes, I believe I understand now.
With the multi-router I sometimes use a template and sometimes not. I always work off the center.
When making fingers for a cabinet base (3 ½” width) for instance I do not use a template. In this instance I only have 3 fingers total – one large finger coming from the side and two on the front piece. I start by forming the two outside fingers of the front piece. I register the piece on one side and route just enough to form the one finger. I then turn the piece over and register on the other side and form the other finger then waste the material in between. To make the mating joint I then set up the multi-router to route a notch to match the single finger on one side. At this point I only have to turn the piece over and notch the other side to form the one large finger.
When I do larger multiple finger pieces such as large drawers, I use a template on the multi-router. Again, each part is registered twice – once off both sides. I route two or three fingers then turn the piece over and route the same two or three fingers in the other side. When making the mating joint I route from one side then the other but this time I waste all the material in the middle to receive the one large finger formed by the first joint. With this method I am able to make fingers on any size drawers and do not have to worry about making the drawer a particular height to match the number of evenly spaced fingers. The large finger in the middle grows as the drawers get larger – adding to the effect of visually weighting the larger drawers on the bottom.
You might get a hint of what how I do fingers on my website at:http://furnituremaker.com/Mediacabinetprogress.htm
I find routing from both sides to be easier and less prone to problems. Since you are making all equally spaced fingers, I would work the joint on Baltic birch templates. This could be done with my method (in principal) using a table saw with a dado head. This would take some patience, but I believe registering from both side would help in accuracy (each inaccuracy adds to the misplacement of the next finger until the end finger on the far end is way off). I would lay out one of the mating joints out on the Baltic birch in pencil. You might set up a stop system with a spacer to achieve the 2” spacing. With my method the center finger may be a little off the 2” size but hopefully not to the point where your eye can pick it up.
For the mating joint I would use the first template to trace the outline out on the second template.
For the second template you would not use the method made to produce the first template – just try to make a match. A good match may take a couple of tries.
The templates could then be set up to route the fingers from the top as you would with a commercial dovetail jig – attaching a board to the template to clamp the part to.
I hope this makes sense and is of help.
Darrell
Thanks Darrell,I think referencing off both ends is the ticket, I've been only working from one edge, and as you say, any error is magnified the further I get from the reference end.Thanks again for the help!Jeff
Hi Darrell,I'm finally getting around to the G&G part of my house, still not done. I had a question about approx. 2" long finger joints, to put on the ends of the mantel shelf support, using 2x4 lumber (VG fir). I was thinking 1"-thick side fingers and 1-1/2" for the center finger.The questions are:How proud should the fingers be? 1/8" seems too small.Should there be a square (flat) section before a radius? (And should there be a radius?)Are the molding fingers pillowed like the furniture ones?thanks,
---mike...
Cambridge, Mass.
Hi Mike,
I am a little unclear on one part of your question: “Should there be a square (flat) section before a radius? (And should there be a radius?)”
I think I understand most of your question though - please let me know if my answer covers everything.
The way I do the fingers is a process that seems to be in evolution. They way I describe here is not how I did it a year ago - a year from now, I may be doing something different yet. Consider my method a starting point – use all or part of what I do.
I radius the face edge of the fingers with a 3/16” radius all other edges get a 1/8” radius. The fingers are proud by about 7/32”. I pillow the face of the fingers just slightly.
I assume you mean 1 inch wide (instead of thick) side fingers and 1 1/2" wide center finger - my inclination would be to go a little narrower on the side fingers and a little wider on the center finger.
I will upload two images - a drawing and photo that may help illustrate how I do the fingers.
….Darrell
