I’m making cabinet doors and need to put glass in one and I’d like to have muntins(?) installed.
Any help would be appreciated.
4Runner
4Runner
Well I just posted a link to my review of the sommerfield bit set that will do what you want. There are many ways to do it from hand cut to the bit sets like I use. Several vendors make them. The material you are cutting adds some thing to consider as well. I did figured cherry and it chips like crazy so that provided challenges while the poplar I used to learn, was easy. If you are to use muntins, the biggest thing I found is sneak up on that final cut and use a story stick to get that final cut tested on scrap and then and only then cut your good stock. Anyway, take a look at my post if you have any questions about that particular set let me know. I had never made a glass door with muntins till this set and did make mistakes along the way and wasted a bit of stock but not too bad. I liked the end product. Take care.
http://forums.taunton.com/fw-knots/messages?msg=46839.1
