I am currently building a maple display case 24″in deep X 80″in long x 72″in ht. for the shelving- 3/4″ thick x 19″in deep x 73″in long shelving design- 1 Front rail & 1 back rail 3/4″ x 3.5″wide x 73″ long 1 centered stile / left end stile / right end stile 3/4″ x 4″wide x 13″long 2 stiles in between 3/4″ x 3″wide x 13″long Then, (4) 1/8″depth, routed out in-lay / rabbetted to receive 3/16″ thick glass 14″wide x 16″deep. the glass will in-lay on a 1″inch ledge on the rt & left sides (on 3″ & 4″ wide wood stiles), and 1.5″inch ledge in front and back (on 3″inch wide wood rails) . with this being known, what is the approximate weight bearing capacity in the center of the in-layed glass part of the shelf? where are the stable / breaking points of a 3/16″inch thick piece of glass on the flat (horizontally)? are the 1″ & 1.5″ wood ledges sufficient for supporting that size piece of glass 3/16 x 14″ x 16″ ? any tips, advice,……? Chipper 3/5/2004 Thank You!!!!!!!!11
Chipper,
Provided that the glass is evenly supported, the glass panels could each easily support a hundred pounds or more, probably quite a bit more. It is important that the wood frames stay flat, if they warp, the load on the glass would get concentrated on two opposing corners which would lead to cracking.
Of course dropping a hard heavy object on the glass would also cause shattering, even if the panel could support the load if it were carefully placed.
The ledges only need to be around a half inch wide, yours are much wider than they need to be, but they won't do any harm being that wide.
If you wanted to be extra careful, install tempered glass panels which are stronger and if they did break, tempered glass doesn't produce large dangerous shards the way ordinary glass does.
Glass is easily scratched, try not to slide hard objects like pottery on the shelves or, better yet, apply small soft pads on the bottom of hard objects placed on the glass.
John W.
John
Temperred glass scratches VERY easily. I would recommend annealed glass.__________________________________________________________
Michael in San Jose
Freedom from mental disturbance is the very most for which one can hope.
Epicurus (341-270 BCE)
Have you tried asking a glass supplier for technical info on shelves and recommended types of glass. I'm sure there is technical data available.
Chipper,
The March, 2004 issue of Wood magazine included a "Smart Builder's Shelving Selector" that included the maximum load, in pounds per square foot, for annealed glass used as shelving supported at each end:
Thickness 12" Span 24" Span 36" Span
1/4" 74 lbs 16 lbs 5 lbs
3/8" 197 lbs 46 lbs 18 lbs
1/2" 345 lbs 81 lbs 33 lbs
I hope this is the kind of information you were looking for.
-Jazzdogg-
