Hi All,
I am planning to build a glass topped coffee table. The top will be a panel and frame with the glass covering the panel only. Do I need to do any special finishing of the underside of the panel? I usually use tung oil to finish. The panel will be solid curly maple.
Thanks.
Paul Ebert
No special finishing required to either side of the panel.
*Paul, My glass store recomends that the glass NOT lay flat on a finish. The supply with any glass Cork or clear plastic disks about the size of a nickle (5/8 ") to put under the glass. I have topped several tables and there is no effect on the glass or wood. However, my grandaughter tries very hard to pick the disks up.Warren
