I have always used titebond II glue when gluing up table tops, and have never used Gorilla Glue. I would like to here your oppinion as to the pros and cons of each.
Thanks to all !!
Thanks to all !!
Bob, I too normally use the yellow glue, though I usually use elmers which has a small work time. I really should use the tbII to get a little more time when gluing up cases etc.
I have used gorilla glue for an outside table and it is holding very well after one year outside. It works easily but it does foam up if too much is used and it is almost impossible to get off your hands.
The instructions say to wet one surface and apply glue to the other. I always have applied glue to both using yellow glue.
So I guess to summarize, gg is very strong, waterproof, fairly easy to work with, but foams, is expensive and wear gloves.
steve
Bob,
One advantage not mentioned in Howie's otherwise excellent post is that Gorilla Glue is much easier to clean up after it's cured. The foam that oozes out of the joint cures into a hard lump that is easily cleaned off with a chisel, and leaves no residue on the wood to mess up your finishing process.
BJ
I never use a yellow glue for panel glue ups. Particularly, I never use a "water resistant" yellow glue. These adhesives a very subject to "creep" and will frequently have glue lines that raise up to a year later. I use urea formaldehyde adhesives like DAP/Weldwood Plastic Resin.
Here are my thoughts about poly glues.
First, let me say I am not a fan of the poly glues primarily because I have found no advantage to them over standard PVA glues when gluing wood to wood joints except for gluing oily, exotic woods. "Creep" is much less of a problem but there are other adhesives that are creep resistant such as plastic resin and hide glue. I'm sure there are other opinions however.
That said, like any PVA glue (white or yellow) the poly's are no stronger than the wood itself--and may be weaker if they are not used correctly. They cure by a reaction with moisture but many use too much adhesive and moisture. Excess moisture increases the reaction but shortens open time--one of their claimed benefits--and results in excessive foaming and a weaker joint. If the wood is at a moisture content of 10% or more, additional dampening is probably detrimental, not helpful. There are now PVA glues with extended open time. In fact the white PVA has virtually exactly the same open time as the poly. The yellow PVA was formulated originally to respond to woodworkers who wanted a faster setting adhesive. Strangely, some poly glues are now being marketted that have a shorter open time and faster cure because some wood workers have complained about the longer clamp time required for the original polys.
Some poly adhesives are certified to meet the ANSI Type 1 waterproof standard which means they can be used for totally submerged applications. However, for normal outdoor use, a type II adhesive will work as well.
While "gap filling" they fill gaps with foam which has no strength. The adhesive expands as it cures tending to force glued surfaces apart so tight clamping is required. They also require that the clamp pressure be maintained for much longer than most other adhesives.
It contains hazardous materials and should be used in a ventilated area and kept away from skin if you believe the Material Safety Data Sheet. If it gets on your hands, only time will will remove the stain.
Finally, they cost much more than other glues and IMO, do not offer many advantages over less expensive adhesives.
For and against, Howie has it right from start to finish.
If you use this glue correctly "it's stronger without question" my opinion.
SA
