Which PVA glues, if any, cure to a hard glue line which resists creep under bending stress? I have seen one reference stating the TiteBond I cures to a hard line.
PVA creeps. Unibond, epoxy, or similar should be used for a hard glue line on all but the mildest of bent laminations.
+1
I did some testing on this with PVA glue. Specifically I was using Titebond II on rocking chair rockers. I looked at both initial springback, and creep over time. I found that with (8) 1/8" laminations on a bending form with a 42" radius, there was negligible initial springback. Next I compared a rocker fresh off the form to one I made several months ago. The curves were identical. The edges were flush. No issues whatsoever with PVA and this type of lamination.
If you are planning on using a very tight radius, or very few number of laminate strips, then you might have a case for specialty glues.
Thanks to both for your comments. I have used Gorilla Glue previously and had good results, but I didn't want to deal with the cleanup mess this time.
PVA is white glue, like the Elmer's we used in school. PVA will creep, for sure.
Yellow glue such as Titebond I and II are aliphatic resin glues. They will not creep.
Unfortunately, I don't think the color is an accurate way to determine the glue type. According to Titebond, TB I is an aliphatic resin and TB II is a cross-linking PVA.
From their website:
