Here’s kind of an off the wall question. On the DIY channel show Wood Works, David Marks uses a small hand roller for spreading glue. It looks like it has a wooden roller, my guess is he waxes it heavily to enable easy cleanup and keep glue from sticking. I’ve been looking high and low for a similar roller, can’t seem to locate one anywhere. I’m not looking for one of those plastic bottle glue roller kits. I want a small hand roller like the one on the show. Hopefully some of you watch this show as well and know what I’m referring to. Any ideas??? I’m about to give up and try to fab one up by hand….
Look in the paint dept of a paint store. They usually have something like that.
jeff- the roller he uses what is called a printers brayer, i get mine from a local art supplies shop. that has a very extensive inventory . they come with diffrent sizes and quality i use the one with a solid metal rim 4"- 6" long then if has a rubber outer covering that the vehicle for the glue. prices vary from 10$- 20$ . and after a while toss it. if you get a wooden rim it will not stand up to soaking to get the glue off the brayer.
Awesome. I'd tried art's and crafts supply but I guess I didn't try hard enough. Thanks!! All they carry at the box stores in the paint dept is sponge rollers, not what I was looking for...
What you're looking for is definitely a specialty item and thanks to alias, we know what it's called. alias- I knew where I had seen them and what they were called, it just wasn't coming. Thanks.
This has been driving me nuts. Couldn't find it on Amazon, but not because the didn't have them, I just didn't know what they were called. After I found out what they are, I found several on Amazon. I guess hand roller is just way too generic LOL. Anyway, I beat feet down to the local arts and crafts store and they had a rack full of them. I'm happy now!!!
Wallpaper seam rollers are similar and are sold anywhere wallpaper is sold.
Joewoodworker has several. I have the $9 one. It really is good quality. Just rinse it off after each use.
http://www.joewoodworker.com/catalog/default.php?cPath=37&sort=2a&page=2
They look similar to the type I bought at the local crafts store except they are missing the little wire legs on each end on mine. Holds the roller up in the air a little to keep it off the bench when it's not in your hand. Paid a couple dollars more for this one too, about $12.00. The roller is rubber, is Joe Woodworkers roller rubber also??
Joewoodworker's is a sort of semi-rigid foam and consequently doesn't slip and spreads glue beautifully.
It's hard to get excited about a glue roller but this ome did impress me!
I was real dubious about rolling glue bottles till I broke down and got one, Believing they would be impossible to clean. The rolling glue bottle from Eagle America. Works great, You can seal it with a built in plug, Store glue, Refill from a gallon jug. The bottle is poly, and the roller is rubber. Unit cleans up in a flash with warm water that is if you use Titebond. DON'T use with polyurethane though.
Bruce S. Counter Sales, Tech Rep. http://WWW.EAGLEAMERICA.COM
Indeed you are looking for a brayer. You can find them in big box craft & hobby stores. Get one that is slightly softer than rock hard rubber. Mine is 4" wide, approximately 1"+ in diameter.
Keep a plastic bowl of luke warm water handy and when you are done spreading glue just toss it in the water. After your glue up is clamped, simply slosh it around in the water and dry with paper towel. It will do the job and should last many lifetimes.
Still learning, Larry
What about a J-roller? They've a rubber roller, metal furrels and handle. Better yet, they're available in every hardware store.
Thoughts?
Marty
In my desperation I considered a J roller. It's kind of like using a framing hammer to do trim work, too big for the job. I did find the brayer roller in a local Crafts store (Ben Franklin), in a variety of sizes, for about $10.00. Very pliable rubber roller, should work just fine...
Old post but I'm new. Pasta dough roller. Just rinse when done. Could probably dremil out ridges on one of the rollers for spacing so you have both types on one tool. *not alot of cash creates ingenuity!
