I miss some glue run out on a piece i’m working on and it appears that the yellow glue stained the white melamine. is there anything 0ut there to help remove this stain? i’ve tried goo gone but not that good. any help would be appreciated.
Should be able to scrape most off with a sharp scraper...then varsol,lacquer thinner or methel hydrate should remove the rest.
cheers,
silver
Varsol -- that's a blast from my past. Haven't seen/heard the phrase in quite a while. Last time I used it in conversation, I had to explain it.Ta,Leon Jester
thank you gentlemen for your help will try lac. thinner, glue come off with sharp chisel just appears to be a stain left over.Thomas B. Palumbo
CUSTOM WOODWORKING
before you try any chemical stuff, try flaking it off by running a finger nail over it. My glue squeeze out generally always flakes off, sometimes needs a bit of help from a sharp chisel in the corners.
I've never observed any "stains" left behind.
Eric
