I’m almost finished with the Base for my Klaus Traditional Workbench. I’ve got to sand everything before I assemble.
According to the article in “The Workbench Book”, the stretchers that tie the two supports together are attached with 1/2″ x 6″ bolts. Are they also glued? Is it bolted for the purpose of breaking the table down for transport? Or is it bolted AND glued for strength?
Thanks!
Mark
I have a similar design for my workbench base. The bolts tie everything together solidly and no glue is required. For which you will be thankful if you ever need to transport the bench.
