Hi, I just put some Carter bandsaw tires on my 18 inch BS and I have a 1/4 inch gap on the sides. I initially thought that once I installed them (as per instructions-hot water 5min) and they cooled that they would stay in place. But…they are not. What would be the best adhesive to use? I’m afraid if I use contact cement, if I don’t get them perfect then I will be stuck? What about 30 min epoxy? Any advice would be greatly appreciated. Cheers, Derrick in BC.
Have you tried conatcting the tire manufacturer or looking on their web site for info?
No, I have not, but thats a good idea so I will try. thanks Rick.
Try Iturra Design in california. They have a special adhesive they sell especially for bandsaw tires. They also have excellent advice on mounting/glueing new tires on.
Birdy
Birdy, wrong side of the country. Iturra is in Florida, phone 1-888-722-7078.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
There are some cyano-acrelate glues specificly for rubber. I am not sure if this would be a good application for it or not, however I am about to be faced with the same problem soon. The upper tire on my big saw is cracked, and flapper started slapping the other day. I used some of the CA glue that I keep around for turning, etc. to stick it down. so-far, it has held.
Here is a site if you want to consider this angle.
http://www.e-zbond.com/Product.htm
I use rubber cement applied to the wheel only. The most important part is to use a rolling technique to distribute the rubber tire evenly on the wheel so there are no rubber bumbs happening under the blade as the wheel turns. A laminate roller or even just rolling the wheel on a smooth floor distributes the rubber evenly around the wheel. Aloha, Mike
Derrick, given that the Carter description allows for the possibility of gluing, seems like they should have a recommendation. Nothing in the instructions? [edit: Carter customer service 1-888-622-7837] I'll second the motion to call Iturra at 1-888-722-7078 if you don't have a contact number for Carter.
Edited 5/31/2005 11:33 am ET by forestgirl
rubber cement.
Thanks all for the advice, I contacted Carter and they said to use a 2 part epoxy. Cheers, Derrick.
