I’m building a custom mantle for my house. In order to keep the weight of the mantle down, I’m using MDF crown moulding for it. The crown is also what I used for the room.
The top shelf will be a clear 1″x8″x7′ long piece of pine. What are you recommendations for glueing the mdf to the pine (the pine is unprimed and the mdf is preprimed)?
The glue I have elmers and titebond fast set wood glue both absorb into the cut ends of the mdf. I was wondering, for the non-cut edge (that contacts the prime) is wood glue even the right thing to use?
I also have used Locktite’s Grabit(?) latex construction adhesive to mount small pieces of trim. Would this be the right adhesive to use along with some brad nails?
I've found polyurethane to work well in these situations. Melamine adhesive is another option but it is a specialised adhesive with a limited range of uses & may not be worth buying for a small project. Epoxy will also work very well.
Don
I wouldn't hesitate using yellow wood glue.
