I’m new to turning and have a question about gluing blanks for turning. As an example, say I want to make a footed vase with contrasting wood for the base and the body of the vase. I also want to put a contrasting rim on the top edge of the vase. The grain would run the same direction as the lathe bed, so the glue joints would all be end grain to end grain.
Would epoxy be strong enough to keep the whole thing from flying apart or is there another solution?
I know that gluing the blanks long grain to long grain would solve the problem, but I want to take advantage of the grain patterns of the wood parallel to the lathe bed.
Thanks.
Alan
I use regular titebond yellow glue. This has held fine - epoxy would probably work but is much more expensive than yellow glue. The key to my glue ups is a press that I made useing a veneer clamp to put even pressure when doing these types of glue ups. Below is a link for the press. Good luck with your turning Jeff.
http://www.turnedwood.com/tools&jigs.html#NewPress
Wow! What an incredible website you have. After I wiped all the drool off my keyboard, I printed some of your pages to study later, and will definitely return often. Your work is also outstanding- SOFA quality. I'll be checking out the links to other turners as well.
I'll try using the yellow glue. My biggest concern, I guess, is when the joint ends up being a very small diameter, like a finial or small handle. Judging by your work, it appears to not be a problem. I would assume you don't turn that particular joint down to its final prifile until after the rest is done to avoid undue stress. Would that be correct.
Thanks again and I'm looking forward to going on your site again.
Alan
I'm glad you enjoyed the link but I can't take credit for it. It is a great site that I came across when doing some searches. Good luck with your turning.
Alan,
I wouldn't turn a piece that had been glued end grain to end grain regardless of the type of glue. I would search for an arrangement that allowed long grain to long grain glueing.
Happy New Year,
-Paul
I concur with Paul's analysis that end grain to end grain is not viable. However, if you turn a mortice and tenon on the piece with the tenon being smaller than your final work diameter, then you may have a viable solution.
Bill
