I searched but didn’t find any threads, so forgive me if I am repeating a thread. I have a client who wants me to do a desk covered in leather. The desk will be ac seven layer plywood with the leather attached only to the top surface. He wants the look of the plywood edge with the shoe leather on top. My question is whether anyone has recomendations about type of glue and method for this. The leather is in largeish sheets that lay almost but not quite flat. I had been thinking about using hide glue.
luke
I have had good success with spray contact. I like to leave the leather larger than needed, and spray both parts, and then quickly lay the substrate on the contact while still wet. You can then flip it over and smooth it out with the hands from the middle out, and even roll any problem spots, or even lift the edge, and spray in a little more before stretching and re-sticking. It will still dry OK, and is safer this way than trying to picking up the leather, and having it fold and stick to itself.
Trim the edges after everything has dried.
I use Master cement from Marilu products (952-854-0140) in Minnesota. It is also great for leather and veneer because it is thin enough and flexible enough to avoid any glue thickness problems as well as expansion and contraction. Water proof and can be removed by using Master thinner if the leather needs to be replaced. No need for a veneer press with this product as it sticks on contact and it doesn't warp the veneer or leather because it isn't water based. Dries and sets fast so you aren't waiting to continue on with your project.
I have used contact adhesive (the same I use for laminate) for leather covered inset panels. There are products specifically for the purpose. Search leather adhesive in Google and you will find several. For your aplication I think that I would use a product intended for the application.
Pardon my spelling,
Luke,
I've have used wheat paste with excellent results. I used to be able to buy wall paper paste, but I can't find true wheat based pastes anymore, so I have to make my own from hot water and flour ( there are recipes on the net).
I think regular liquid hide glue would also work well.
The only thing I would be concerned about is the warping from these water based glues, so I would glue the leather on, with the top attached to the base.
Rob Millard
This may help.
http://www.thistothat.com/
Another tip is to be aware of / beware of the bias of the leather. Leather is more of a textile, and has a 'give' to it depending upon how hard you pull or push. Different cuts of leather have differing bias. You specifically said "shoe leather", so I suspect it has a pretty low bias, but work the pieces by hand to see before you put the glue down.
If you end up pushing or pulling too hard while working it smooth, you may distort the grain of the leather and create a noticeable blemish. Unfortunately, "too hard" in this case is going to be dependent upon the cut of leather.
Hope that helps save you from a mis-step!
Glen
Thanks for the tip. That is exactly the sort of thing that I wouldn't have thought of until I'd ruined a couple of pieces. I'm going to try it with hot hide glue, so at least I could if necessary get it back off. Thanks for the advice on the glue everyone. Any recommendations on gram weight or strength of glue for this project?
Traditionally hot hide glue is used for this application, in my experience rabbit skin glue works much better than regular hide glue.
Test on a scrap piece for dilution, you don't want the glue to soak the leather and come through.C.Edited 4/17/2007 6:38 pm ET by citrouille
http://antiquerestorers.com/LEATHERinstall.htm
Check this.
I have used contact cement, dry method, on leather faces of mallets that have taken a beating for years and are still going strong. You have to be very careful using the dry method though as once the two surfaces touch they are stuck for good. Keeping them apart with a sheet of heavy paper works well. You slowly remove the paper as you press the dry glued sides together.
Yellow glue did just fine for me. My earliest desk had been used daily for more than 20 years.
Best wishes,
Metod
Glue to use? What better than animal glue for the task. NO, I do not hate animals.. I would think that I would hope some animal died to make the glue and NOT killed for it... Never had a cow or a horse as a pet.. I rode many horses and as a child I had to clean the cows butts.. Do not ask me.. I really did it.. Not that bad of a job.. I think better than chopping wood for the fire place...
When I die.. I would have no problem with somebody making glue with my remains.. I could live along time gluing some venner to a front drawer that some beautiful woman opened every day....
“[Deleted]”
