I have been making cutting boards for several years and have had good success glueing them up, cleaning the squeeze out with a wet rag, and going straight to the planer once they dry. So right after buying a new planer, Dewalt 735, I was planing some boards that had a little glue left on them from where the clamps were. Long story short, is that what trashed my planer blades? I have a vague recollection from a class in college and the teacher warning of this. I was not using doing any thing different than I usually did with my old delta portable planer. Any advice is apreciated.
Rob
Your dried glue is probably harder than the wood and is knicking your blades (HSS, right?).
When I do this, I give the glued up panel a quick sanding with 60 or 80 grit before using the planer. I still get the occasional nick which leaves a tiny ridge on the board, but those are removed during my final sanding.
I use a cheap paint scraper to get rid of the glue before running anything through the planer. Dry glue will tear up blades.
I'd avoid sanding before the planer. Chances are you'll leave some sanding grit in the wood, and that'll mess up your blades too.
Edited 5/25/2009 10:20 am ET by Mahoganaholic
I use either a hand held scraper or a plane iron hand held holding it in almost a vertical position to run it. Will the glue chip blades on a planer? In my opinion... I know it will.
Sarge..
thanks for the confirmation
Rob
