Hi, I’m about to glue up 8 drawers, each being a “flock of dovetails”. Im a beginner and the dt’s were done on a jig. For the carcase of this project, I’ve been using a polyurethane glue (similar to Gorrilla Glue) for edge-joining and other glue joints, and I really like it because the clamp time is only a few hours. And who has enough clamps or space to wait overnight? With the drawers, Im afraid that if I use the polyurethane glue without clamping, the glue may swell and cause the drawers to warp or move. If I use white glue, I probably can just tap the drawers together with a mallett and call it good. What do you suggest? Regards, Erik
Gorilla Glue has up to a 4 hour set time. You'll need it clamped tightly and you'll be wiping foamy squeeze out off the joints for at least the first 3 hours. Thats not my idea of fun and I doubt it will make a dovetail joint any stronger than it already is. I would use titebond glue, bang them together and lightly clamp and check for squarness. Wipe the excess off and your done.
Steve - in Northern California
Just a note , I have two dogs that got into a bottle of Gorrilla G lue got them to the vet within 30minutes . the vet removed a semi- solidified mass the size of a basball capfrom their stomachs said he was going to use this info for a paper.
The only thing I now use any kind of poly glue for is to glue bricks together around flowerbeds. Works great for that. Other than that, I don't use it. Oh wait a minute - I did use some to glue redwood expansion strips back into a concrete driveway.
White glue would work fine for what you describe.
PlaneWood by Mike_in_Katy
PlaneWood
Thanks, Mike, Steve, and "nails". Plain old white glue it is. Is it time to call it a day and go home to the woodshop yet?! It won't be long now till I post some photos of the finished product! While I'll be taking the credit for the dresser, the valuable feedback that I've gotten from people like you (and Dano) has been extremely helpful. In fact, last night, I acutally used a hand plane for the first time in a situation where I otherwised would've sanded to get the two adjoining pieces smooth, and I liked it! I think I might be developing a taste for Fine WoodWorking!!
Best Regards, Erik.
