I am just starting out and have some questions concerning wood grain direction and glue. What is the proper direction for the grain when gluing peices together – especially mortise and tenon joints?
Thanks – Tom
Thanks – Tom
I don't think I necessarily understand your question. Could you ellaborate please?
If grain is running one direction on one face of the board, it is running the opposite direction on the opposite face of the board (usually). So if this is what you mean, no consideration is given to grain direction on mortise and tenons.
Perhaps this addresses your question:
Sidegrain glues well, endgrain much less well, so holding power depends more on sidegrain contact than endgrain contact. The mortise is an elongated hole, and should be elongated in the direction that will give sidegrain on the largest flat surface. This is also the direction that will weaken the mortised piece the least, since it cuts through fewest fibers. The tenon must have grain oriented along its length, because it must be strong.
