Hi, Peter,
I just finished a small table with marquetry images on the base and top. The background veneer is walnut burl, which is quite porous. I ended up using Deft brushing lacquer and used ten coats before I was able to fill in the porosity and build a finish which could be leveled. The end result was fine, but the time required is excessive.
My question is this: Is there a grain filler which would fill in this porosity without an obvious color that would detract from the marquetry? Any guidance would be appreciated.
Thanks and best regards, Tom Abbott
Hi Tom,
It's been a while. It's funny, I thought of you the other day and here was your post.
You didn't say what type of woods you used in the marquetry. I'll assume they were non porous
When faced with that surface I would seal it with a thin coat of shellac or two at the most (if the walnut was very porous)
Then proceed with a paste filler. The only thing left behind will be in the pores of the walnut and will not affect the sealed surface surrounding it.
After it dries well, proceed with your finish. You'll find it goes a lot quicker when the pores are even partially filled.
It was good to hear from you. I hope things are well.
I've got a Master Class article coming out in the next issue. Definitely not "brown furniture" in this one
Peter
Peter,Thanks for the reply. I did take some pictures, and have attached two to show the table and marquetry. A friend recommends a clear grain filler made by J. E. Moser. Ever hear of it?I look forward to seeing your new article.Best regards, Tom.
Tom,
I haven't seen the clear grain filler. If it is water based they can be a PIA to work with.
My feeling on the depth of color on the walnut is that it would take a colored filler very well.
If the clear filler can fill with no color shift in the pores, it may be what your looking for.
As you know it's had to determine that without trying it. Does your friend have any leftover so you can make a sample?
Peter
