Is there a way to look at the grain direction so that I can see where I will have a problem with tear out when I do pattern routing?
Greg
Greg
Discribe what kind of patters
Discribe what kind of patterns you are using. In most pattern useages you are going to be going uphill and down hill with the grain.
Tear Out
When I route an oval pattern using Cherry wood I would come to a section in the wood that creates the tear out. I know at that point the solution is to route down hill but is there a way to identify the area before I come to it so I don't tear the wood?
Greg M.
Pattern complexity?
Would it be possible to scribe the cut line with a knife prior to routing?
Also, what style of bit are you using? If you can rout the bulk of the area first, and then sneak up on the perimeter using a down-spiral bit, that might help in achieving a clean line.
ROUTING
Thanks for the tip, I'll try it tomorrow.
Greg
Tear Out
Hi Greg ,
My guess is when you get to the end grain the tear out appears .
Smaller cuts , more passes , try climb feeding at least those areas .
best regards dusty, boxmaker
