I’m getting ready to clear coat mahogany veneer cabinet doors that have been installed for some time. There are grease stains on some of them and I’m wondering what is the best/safest way way to remove the stains prior to finishing with a water based coating? I’m leaning towards a rag or steel wool dipped in mineral spirits.
Edited 7/6/2005 9:20 am ET by teepee
I'd avoid the steel wool in favor of "Scotchbrite" pads if you're planning to use a water-borne finish; steel wool fragments under water-borne finishes tend to rust.
-Jazzdogg-
"Don't ask youself what the world needs. Ask yourself what makes you come alive, and go do that, because what the world needs is people who have come alive." Gil Bailie
teepee
Use Acetone,
pour a small amount of acetone on the grease and wipe off with a clean rag.. Repeat untill grease mark is gone..
teepee,
My solvent of choice is denatured alcohol. It is a nonoily solvent (unlike mineral spirits) not hot enough to spread oils further (unlike acetone), evaporates very quickly and removes skin oils, food oils, leaves no residue and a lot easier on your skin. Additionally, it wont soften most other finishes except shellac. Good luck with it. Aloha, mike
when you call acetone "hot" I assume you mean it has a fast rate of drying. It does which is why it doesn't spread grease as you suggested. I've found it to be the fastest, easiest, way to remove grease/oil without leaving anything behind..
On the other hand alchohol doesn't disolve all greases or oils and when it does it takes more applications to be effective.
On the other hand,,..... ;-) acetone is harsh on skin and bad for you.. It is easily absorbed thru skin and can attack your liver with prolonged exposure.. Alcohol is far more benign..
Thanks to all for your responses. Denatured Alcohol did the trick on most of the stains, but I did find it necessary to use acetone on others. The really tough ones required several repetitions of wiping with acetone, then sanding. Very faint shadows remain from some of the stains but are not noticeable save under very close scrutiny. OK, back to finishing.
