Just received the Greene and Greene Bed Plans with detailed drawings, they look very thorough. I am a bit confused by one item however. I don’t understand how the bed bolt screws into the bed rail, is it a threaded insert? and what is the cross dowel for on the bed rail?
“[Deleted]”
Are you referring to the Gamble House bed by Martin McClendon? If so, the cross dowel is the threaded insert for the bolt. It is a metal cylinder with a threaded hole drilled through it. They are included with the bed bolts specified in the plan.
