I am refinishing a Danish rocker….I think it is made of ash?? I had the rocker dipped at commercial stripper. Now there is a greyish black coloring in the deeper grain (pores) of the wood. I want to remove this coloring. It takes tremendous amount of sanding to get the staining out. Is there a chemical solution…additional stripping agent or possibly bleaching? What is this coloring in the grain from? It almost seems like residue left over from the dipping process.
It's either stripping residue or a chemical reaction with the stripping chemicals (or both). Wet an area of the wood with mineral spirits, naphtha, lacquer thinner, toluene, or zylene to see how it will look when a clear finish is applied. It may be just fine or you may need to do a little more work.
If it's residue, a good wash with lacquer thinner and a stiff plastic or brass bristle brush will clean the pores. If it's a chemical reaction, a saturated solution of oxalic acid wood bleach will remove the discoloration. Try the cleaning routine on an area and switch to the bleach if it's ineffective.
Paul
