I had stated previously that I purchased the Grizzly G0444Z Table Saw & that I was excitedly awaiting it’s arrival.
Well, it’s here & I began assembly last night. Man, this thing is solid! (40 carriage bolts for the stand alone!) I feel like I’m doing it an injustice to call it a “tool”. It seem’s like the term “machinery” is more appropriate. I can’t wait to get this thing humming!
Oddly, I kind of expected a blade to be supplied with the saw, but it wasn’t. I guess that a good blade will be my next purchase.
Grande,
You'll be happy to know ... you don't get a blade with the Griz cabinet saws either. Welcome to the aftermarket world of woodworking...where things really get expensive...lol.
Enjoy your new "machinery"! Most of the stock blades are junk that ultimately get built into the cost of the saw anyway, so it offers a great opportunity to buy decent blade from the start. And let's face it....a great saw with a lousy blade makes for a lousy saw!
Mr Grande,
This is the exact saw I am considering buying if I can't find a cabinet saw used for around the same cost. Can you post whether you think it has enough power to cut the occasional 8/4 hardwood board. Most stuff I cut is 5/4 rough stock that I mill myself but I need a new saw now. My Craftsman RAS just isn't cutting it anymore. (Pun intended). Thanks for any input you can give me.
Tony
Tony, if you use a ripping blade (24-tooth, thin kerf if you want; I use a Diablo by Freud, bought at Home Depot), you should have no problem ripping that 8/4 stuff. I'd also suggest installing one of the orange 'link belts' rather than using the standard belt that comes with the saw. They really help a saw's performance.forestgirl -- you can take the girl out of the forest, but you can't take the forest out of the girl ;-)Another proud member of the "I Rocked With ToolDoc Club" .... :>)
Where do you get the orange belts? Who are they made by? I have heard you mention them before and they look like they are worth looking into.
Tony
We already have enough youth, how about a fountain of smarts.
Here is the Link Belt that Grizzly offers. I imagine that I'll be buying one before long.
http://www.grizzly.com/products/item.cfm?itemnumber=G8127
Here's one source:
http://www.rockler.com/ecom7/product_details.cfm?&offerings_id=6040
Forestgirl,
I've been listening to this discussion and was wondering if the link belts are really worth it?
My Dewalt hybred is only about 6 months old and the belt seems to be fine. The only vibration I notice is when the motor is slowing down after the cut is made and I've turned off the motor.
How tight do you make the belt?
ASK
I have them installed on all my woodworking tools except my shaper and I highly recommend them. Since the belt is designed to only run in one direction use on a shaper is not recommended. The cut was noticeable improved when installed on my Unisaw. When my Grizzly jointer arrives I will not use the stock belts but install 2-3L Powertwist Plus belts. They need to be installed very tight as they stretch during about the first hour of use. They have a joint every 3/4" so you do have a lot of stretch initially.
My contractor saw came with a belt that had pretty good "zig" in it. A link belt helped alot for this machine. I added one to my jointer shortly after, and the improvement was much less significant. The link belts make the most improvement when replacing a problematic v-belt. Many machines run very smoothly on v-belts, and may not need an upgrade. For some situations it's only a nice to have luxury and maybe not needed at all, for others it's more essential.
ASK answered your query well, and I second his info. That vibration you feel/see when the blade is slowing down is evidence that all isn't running smoothly when the saw is up to speed either. The link belt can absorb a great deal of that vibration and your saw will run smoother and more efficiently. It gave my old Jet saw a serious personality transplant! Shop around for the best price.
PS: Make the belt the same "length" as your old belt, check it after awhile for any stretching, remove a link if needed.
Edited 6/11/2004 6:43 pm ET by forestgirl
Thanks all for the info.
Got to go make some saw dust.
ASK
Tony, remember that one armpower (far less than one horse power) can cut down a whole tree. It just takes a little longer.
I build furniture with a 1 1/2 hp contractor saw, including cutting whatever needs cutting. I sand with a 1 HP drum sander, not the far faster 5-15 hp sanders used by a commercial shop. I have a 1 hp bandsaw that I use to resaw 12 inch wood ... slowly.
A lot of the tools are under 2 HP so that they can run on a household outlet. They work fine, but just a little slower. ________________________Charlie Plesums Austin, Texashttp://www.plesums.com/wood
Thats just the thing, I enjoy the process and the finished product. It is going to take me longer because of four distractions anyway (kids). I enjoy the time in my garage almost as much as fishing with the kids and thats why I'm never in a hurry. I'm just looking for a way to improve the process and work a little safer.
Tony
