Grizzly G0540 Spindle Boring Machine
![](https://secure.gravatar.com/avatar/e045309ac8901c12307d96f0e98f8a95?s=52&d=https%3A%2F%2Fimages.finewoodworking.com%2Fapp%2Favatars%2F200x200%2Fg.png&r=g)
I am interested in your experience with this slot boring machine. I’m debating using the miter table vs. JDS multi router vs. the Griz slot mortiser. I’m ready to make the change to floating tenons.
Any comments will be appreciated.
George
While I haven't used this particular machine I have used many types of slot mortisers over 25 years as well as chisel, chain and Maka mortisers I think the horizontal slot mortiser is one of the best kept secrets. I have talked to several folks who have the G-0540 and heard positive things. For the money you can't touch anything else. I recommend you use high speed steel endmills for tooling. Rather than search for an answer you might try going directly to an answer... a review of the machine by a fellow user... http://www.woodcentral.com/articles/reviews/articles_729.shtml
Rick,Thank you for your comments and link. Sounds good and as you say for the money...
I've had one for about a year and don't know how i ever did without it. I use two flute end mills used for aluminum and they produce clean mortises fast. I keep a supply of tenon stock handy and now M & T joints are a snap. Art
Art,I appreciate your response. I'm about convinced. How does it do on end grain for the matching mortise? I'm not familiar with the bit that mention can you describe it a bit more. Who is the supplier? Do they come in different diameters?Thanks,
George
Endmills are used in the metalworking trades. An aluminum type endmill is two flutes with a spiral flute. High speed steel will cut hundreds of mortises before needing resharpening and I pay about $5 to have them sharpened. Go to http://www.use-enco.com http://www.wttool.com http://www.mcmaster.com http://www.mscdirect.com are but a few sources. Commercial slot mortisers typically run about 3,600 to 5,000 rpm so the G-0540 is within that range. Cuts are great with end grain and long grain. Available in many sizes. Typically you only use a handfull of different size in woodworking.Woodworking Machinery Technician
Edited 6/17/2006 7:15 am ET by RickL
I think most of your questions have been answered. For the most part, I use either a 1/4 or 5/16 end mill. I mark the ends of the mortises on the stock, plunge a full depth hole at either end, and then use shallow passes to clean out the middle. I eyeball it and do not bother with the stops except for the depth. There I use a combination of the position of the bit in the chuck and shims to get the correct depth. I added a piece of 1/2 in plywood to the table which allows centering in 4/4 stock. Feel free to e-mail me if you have any questions. Art
Thanks for all of your helpful comments. After I get set up I may take you up on additional advice.GEorge
I have The Grizzly too.
It quieter than the chisel mortiser or router I have used previously and the tooling is cheaper and more durable. It makes a much smoother motice than the chisel mortiser.
It is inexpensive compared to the "real" slot motisers ($400 vs $2000). But there are limitations:
The stops are clumsy to set
It chatters with cuts heavier than 1/8" or slots wider than about 3/8"
It won't center a slot in 4/4 wood without shims
I work around all of these problems and I would not go back to the other methods.
I've used a Rojek slot mortiser and it sounds similar in performance to the G0540 but the Rojek is over $1,700. The commercial ones are more like $3,500 and up for the Laguna, Griggio, Paolini, etc. The only other inexpensive one is the Laguna/Robland which is the mortiser from the combo machine. That's around $600 I think now plus you need to make a stand and get a router for it. It does come with the mortise chuck so you could rig up pillow blocks and a regular motor for it.Woodworking Machinery Technician
