I have been using Hammer machinery for almost a decade – Tablesaw, Bandsaw and Jointer thicknesser, superb macinery.
My K3 tablesaw started seriously vibrarting ten seconds after switching on the machine. I have tried replacing my sawblade but no success.
Did anyone face the same issue?
Any ideas what could be the problem?
Sounds like bearings. Could be motor or arbor, remove the belt and start, to isolate the two. If still vibrating, then probably the motor- a rewind shop can take care of that. If not then the arbor bearings. You can also check runout with a dial indicator, or if bad enough you should be able to detect excessive play with your hand
