When hand dovetailing I find the work will shift around on the bench while chiseling. Do you have any suggestions on how to keep this from happening?
Perhaps I misunderstand the question, but:
Use a clamp or a hold-down to secure the board you are working on?
Holding work fast during hand dovetailing is imperative and problematic. If the work slides in the least on the bench your effort is diminished because the force is diverted into moving the work. I have always held work with screw clamps--two if at all possible. The problem is further complicated by the fact that most Euro benches have a apron at the front edge and the bench is thinner toward the center. This means that the screw clamp can only be positioned in the first two inches of the bench face. I have cured this problem at my bench by gluing a block of wood behind the apron (and between the dog holes) at the point where I clamp work for dovetailing and hand mortising.
I have recently discovered another handy trick. Although it may not gain garner with the PETA folks I position a heavy piece of "bull hide" leather under the work. Not only does it provide a skid free surface it is mildly compliant taking up for a bit of warp in a piece so that it is rock solid on the bench at all points. If stock is bowed (and this can happen overnight), it is quite normal for the outside edge or center to be slightly off the bench. Your force is greatly diminished at these points. Leather cures this problem. If leather offends you I am sure you could find a synthetic material that would do just as good.
I have attached a photo for edification.
Ernie Conover
