Hand held pneumatic spindle sander????
Hi,
I’ve seen pictures of people in some woodworking books of people using a hand held pneumatic sander that looks like a small bakers rolling pin. It has a handle on each end, one of whicg being where the air hose plugs in and appears to be about a foot long total and maybe 2-3″ in diameter. I’ve done some searches on the net (“air/pneumatic spindle”, “pneumatic/air drum”) but all I’ve come up with so far are your standard orbital hand sanders…. kind of hard to search for a tool when you’re not really sure what it’s called — doesn’t look like a “standard” woodworking tool anyway, or at least the popular online retails don’t have it in their catalogs.
Does anyone know what the real name for this tool is and/or where I can find one. Looks perfect for sanding curved work that has already been assembled and as such can’t be sanded on a dedicated spindle sander or drill press.
Many thanks in advance
-Michael
Do a Google search under "Pneumatic drum sander". You'll get pages and pages of references.
We used to use them all the time - called them "rolling pin sanders" or "hot dog sanders". Can't remember for the life of me where I bought them 25 0r 30 years ago.
Try: http://www.louisandcompany.com their # in calif is 800-422-4389 That's where I bought mine 5+ years ago . It has one handle on the end. Make sure you run an in-line oiler with it or frequently(very frequently) and a few drops of oil. These things aren't cheap
Thanks for your reply. I had already tried the search for "pneumatic drum sander" the problem is that what it returns are generally hits for a drum sanders (some for drill presses, some for lathes, some as attachments for die gringers) where the drum itself is air filled.... of all the links that I followed, none were of the "rolling pin" variety, which is why I thought that the item I was looking for had some other name.... I suppose I just have to keep digging. Thanks again.
--Michael
We used to make our own in my furniture factory days. You will need a 5 hp compressor to run the air style motor. Just use an electric drill. You can buy the pneumatic drums from Woodcraft and such for around $50. You can make your own shaft with some bearings and locking collars for a few bucks and you are in business.
Or pay more for this
http://sand-rite.com/touchup.html
The links that everyone as posted are indeed what I was looking for. Unfortunately that is some "long coin" for a tool that is on my nice to have list.... When I was having some difficulty tracking one down, I though about making one using a pneumatic die grinder as the base and retro-fitting a long sanding drum with a new shaft.... What I usually end up with when contemplating buy vs. build for tools is time to build vs. cost. In this case, I think I'll build :-)
Thanks again to everyone for taking the time to respons.
Michael
I've had the same thoughts about building one for use with a die grinder due to the high price of a real rolling pin sander. I use a die grinder to polish my billet wheels 2-3 times a year and it doesn't have any where near the power I'd want in a sander. I have a 4 hp, 30 gal, 11 cfm at 90 psi compressor and it doesn't really keep up or provide that much torque for polishing. Admittedly the die grinder is a $30 el cheapo from Pep Boys but that may not really be the problem. A die grinder air motor is designed for high speed, low torgue applications. Sanding requires low speed and high torque. Maybe the rolling pins are so expensive because of their special air motor requirements and low demand??? Look before you leap.John O'Connell - JKO Handcrafted Woodworking
Micheal,
I don't know how long a drum you need but have you checked out the PC-121 OSS?
http://www.amazon.com/exec/obidos/tg/detail/-/B00004WGQD/104-7326660-1751102?v=glance
TDF
I believe this is what you're looking for.
http://woodworker.com/cgi-bin/FULLPRES.exe?PARTNUM=954-958
Not cheap, but I believe Sioux's quality is excellent.
Michael,
Go to Grizzly's web site and look up the H2881 and the H2882 Pneumatic Drum Sanders. They're $50 and $80. There's no reason you can't use an electric drill to power them.
I hope this is a help.
Larry,
Thanks -- that's about the right price point. Looking at some of the other links that people posted, it's the air tool itself that is expensive ($400) -- most seem to resell a tool made by ARO. I could use an electric drill for this, but that would seem a bit awkward to handle and as someone else mention a die-grinder has too much RPM and not enough torque.... I'm thinking that perhaps a pneumatic angle drill might fit the bill -- 1800 - 2500 RPM with plenty of torque...
Thanks again
--M
