Gary,
I have seen very little discussion of a type of power tool that seems to be a take-off of hand held belt sanders, which I guess I would describe as a hand held electrically powered planer. What are the merits, if any, of such a tool, and what might it best be used for? It seems to me that such a planer might be used to flatten a large panel. Are we too caught up with our hand planes to consider should a tool?
Thanks, Dan
I am also interested in what Gary has to say about this.
I have one-- a Bosch -- and am quite pleased. However, I use it for carpentry, not cabinet work. For example, I have an old barn where repairs have to be scribed and nothing is standard. I use the power hand plane to shape and fit boards and timbers -- and also to create angled window sills, thresholds for doors and the like.It is fast and effective for that kind of work.
I used one to try to plane some oak lumber once, but it is very hard to create even thickness. I have used the Bosch to edge plane some other oak that had already been through a thickness planer. I had cut some downed bur oak on the property and am making a table with a pegged plank top and birch legs and stretchers in the bark. It worked wonderfully for that. I clamped four boards together and planed the resulting wide surface flat. However, they are NOT jointed. For the use to which I will put them, jointing is not necessary.
Joe
So you consider it not so useful for fine work. Would you say then, it might be used as a scrub plane?
Thanks, Dan
Dan:
Really, I do look forward to Gary's take on this, because while I am certainly a user, I am no expert.
That said, I think it might very well be possible to do some reasonally fine work with one if you have a lighter touch than I. My Bosch has a very good depth adjustment that allows very fine cuts. The only real problem I have had is in experimenting with planing wider boards with it. It is not long enough to substitute for a jointer, and too narrow to make a really efficient planer. It does very good duty as a scrub, and pretty good service as a smoother although the surface you get with rotating knives willl never be as clear and smooth as one from a traditional hand plane.
I have some very old rough walnut that I have been thinking about doing something with. I will use the Bosch as a scrub and smoother to see what I have before I make more plans. Depending on the use, and how it comes out, I might accept that surface, or I might not.
Joe
Thanks for your thoughtful insights. They will give me a head start, and keep me from reinventing the wheel in this matter.
Dan
Dan,
The first time I saw a power planer, the guy who was demonstrating it had only a thumb on one hand. This kinda threw me off my feed for awhile especially when it came to power planers.
I know some carpenters love them for trimming door edges and they can do a nice job when the grain is wacky and prone to tear out. But nothing beats a hand plane for the quality of finish, smoothness, and sheer satisfaction of using a well tuned hand plane.
It's always a question of why you're building: for money or for love or some mixture of both depending on the day and how late the job is. Best of luck. Gary
