So I have been getting back Into wood working after a multi year lay off. I realized I needed a plane, but wasn’t going to lay out 400 to 500 for a machine (at least not for a while). So cheapo that I am, I bought a Stanley Bailey No 5 (series 16, I think) for about $25.00. Cleaned up the rust made sure the sole was flat and sharpened the iron. I got it looking quite nice, and was eager to try it out. I made super fine shavings – very thin – in oak (it’s all I had on hand) but could not get larger shavings. The plane would bind up. Anyhow. I made what I though was an appropriate amount of shavings – two handfuls and called it quits. I realized the next day I had th bevel upside down and was essentially using it as a scraper. UGH.
Has anyone else ever done that – I don’t really want to be alone on this. Also, do you think I need t go in and resharpen? Lastly, I looked at the bevel on the iron pretty closely and noticed a tiny tinge of blueing in the very center of the blade. I must have generated a far amount of heat from the friction. Have killed the iron? Should I grind of a 1/16 to get to “fresh” iron? I haven’t had a chance to use it with the blade in th correct position so I don’t have a report on how it performed.
thoughs? (Besides I’m a dope)
Your not alone!
that is my story, almost exactly. I just had to laugh at myself... I then renewed the edge on the blade, turned it over and all was right with the world. Only if yours won't hold an edge, should you need to do anything more to the blade... Should be fine with quick resharpening.
